3D Artefact
This topic has been viewed 13555 times and has 20 replies
rdorsch
3D Artefact
Post by rdorsch »
I see here a 3D artefact, which I cannot explain
http://netcup.bokomoko.de/~rd/sweethome3D/sh3d-artefact.png
I surounded the artefact with red.
The complete model is here
http://netcup.bokomoko.de/~rd/sweethome3D/treppeNO.sh3d
I am running sweethome3D on Debian Linux 8.0
Can anybody confirm the artefact in the model (i.e. that it is a sweethome3D issue and not an issue on my machine)?
Any other hint what could cause this is welcome.
Rainer
Re: 3D Artefact
Simple problem, simple solution: Uncheck the ceiling in the room on the top floor.
Because of the sloping walls, SH3D has a problem drawing the ceiling correctly. If you want a sloping ceiling in this room, draw two separate rooms for each half of the slope.
rdorsch
Re: 3D Artefact
Post by rdorsch »
Thank you, Hans, for the immediate reply.
I understand the uncheck ceiling proposal, which works well.
I do not understand your second proposal with the two rooms though....the room which shows the artefact is "Flur" and "Flur" has only one slope for the entire room (?).
rdorsch
Re: 3D Artefact
Post by rdorsch »
I have a similar artefact in the same sweethome3d file for the roof, but seems to be a different root cause.
See
http://netcup.bokomoko.de/~rd/sweethome3D/sh3d-roof.png
I created the roof myself following a howto. Unfortunately I lost my source file, is that the same issue and I would have to remove the ceiling again in the source file?
Re: 3D Artefact
...I created the roof myself following a howto. ..
When you export your .obj file, make sure to EXPORT SELECTION only (not the entire model). If you do not want to make it again, you could apply an invisible texture to that part of your object. ok
rdorsch
Re: 3D Artefact
Post by rdorsch »
Thank you for your reply. Applying an invisible texture to part of an object does not works inside sweethome3d and I need an external tool, correct?
Re: 3D Artefact
No need to worry, it does work from SH3D. If you apply an invisible texture (a totally transparent .png) to your [font=courier new]ground_1[/font] material, the end shape (ground) will vanish. This, btw, is a nice general trick to make elements of some objects vanish.
(You could also add transparency in the .mtl file, but then it is probably better to save the roof as an .obj only exporting selection).
rdorsch
Re: 3D Artefact
Post by rdorsch »
Many thanks for that very useful response.
I used
http://www.sweethome3d.com/blog/2014/08/13/how_to_apply_textures_on_a_box.html
to understand how to apply a texture to my [font=courier new]ground_1[/font] material.
rdorsch
Re: 3D Artefact
Post by rdorsch »
I found another 3D artefact:
http://netcup.bokomoko.de/~rd/sweethome3D/sh3d-artefact2.png
The ceiling is not closed (although this artefacts is not visible in views from all angles, you need to move the camera around). Note, in this floor the ceiling has no slope. I find that artefact in this sh3d file in the Ess-/Wohnzimmer on level EG:
And there is another one:
http://netcup.bokomoko.de/~rd/sweethome3D/sh3d-artefact3.png
This one can be seen e.g. inside Küche on level EG.
Are these also known issues?
Rainer
Re: 3D Artefact
Rainer,
I checked both rooms in your design: there is nothing strange to see.
All walls are the same height, so it would be very strange if something strange would be visible.
Maybe, you have a somewhat older computer, or your video drivers are not uptodate?
(Checked with Ubuntu 14.04 64 bits, SH3D v4.6)
