Can I create one room at a time
This topic has been viewed 3409 times and has 2 replies
MiniMum97
Post by MiniMum97 »
Hello
I don't have a blueprint of my house and want to have a go at one room to see how I get on with this program. Is it possible to add one room at a time rather than having to put all the measurements etc in for a whole floor? What I mean by this is can I do one room now, then if I want add in the extra rooms to eventually create a whole floor, and then even more eventually the whole house!!!
If so, how would I do this?
Thanks all
Re: Can I create one room at a time
No problem doing one room at the time, for instance like this:
- Take inside measurements of your room.
- Use Room tool to outline room (use Enter to insert numeric values).
- Use Wall tool and double click within the boundaries of your room.
You can, of course, start with wall too, then you have to consider that walls are measured along the mid axis and not sides.
MiniMum97
Post by MiniMum97 »
Thank you!
