rose I found the rooms to be much smaller in 3D view than they are.
This topic has been viewed 6217 times and has 3 replies
PeterWeber
Post by PeterWeber »
Whenever I used a floor plan of a flat in sh3d as a background and later on walked through it using the 3D view the areas were always smaller than they are.
Why is that and what to change?
Re: I found the rooms to be much smaller in 3D view than they are.
Not sure what you mean. Were the dimensions in the 2D plan correct? If not, you may have to re-scale your plan. As for the walk-through (virtual visitor), could it be a question of perspective? Does it still look wrong if you adjust the field of view? ok
PeterWeber
What fov should I use to have a real life perception?
Well, that depends on your personal perception of your own field of vision. I tend to find that the default is a bit narrow minded for my taste - and increase the FOV by 10-30%. But a again, it is up to you, but you should see a difference if you try to increase it. See if it works [:)] - and good luck. ok
