And here is another slightly longer walk-thru featuring the transporter room, sickbay, the O.R. Doctor McCoy's office and the lab. Most of this is still very rough. I work a little at a time jumping around from one part of the ship to another. I'm starting to wonder if and when I'll run up against the limit of what the program can do.
Link to video
[Note from moderator: updated link to video]
Starship Enterprise 2nd Walk-Thru
This topic has been viewed 5373 times and has 6 replies
sree.arun.kr
- Country: Kerala, Kerala, INDIA
Re: Starship Enterprise 2nd Walk-Thru
Wah!. [:)>-] Both videos are Super.
Smooth camera path and custom texturing in walls that I like in this video. [:-$]
Thank you. It's a lot of work. I have 3 computers, but I have trouble getting Sweethome3d to run on two of them. One refuses to run it altogether (Dell Dimension 8400 running XP) another runs it but some of the features won't work (Dell GX270 also running Xp) The 3rd computer is my laptop running Vista and it runs it fine, but renders Sloowwwllly.
sree.arun.kr
If you like then do a small tweak to speed up rendering.
Go to SH3D installation folder : "C:\Program Files\Sweet Home 3D "
create a new file : "SweetHome3D.l4j.ini "
Add following lines :
-Xms320m
-Xmx768m
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.min=0
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.max=0
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.min=0
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=1
Save the file and Re-render to see the result. [:)>-]
* .ini is the extension format of the file.
-Xmx768m : is the Maximum Memory to be used that depends upon your computer RAM.
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=1 : is the antialiasing to be used in high quality. Default for minimum 1 and maximum 2 in high quality rendering. Higher value slow down the rendering time but gives quality.
-Xms320m
-Xmx768m
Any chance to share it again or am I missing where the link is? I saw your other posts amazing work!
I just updated the link in the first message. Enjoy [:)]
Thank you. I have also posted the videos on YouTube. And I have a new image recently rendered of the transporter room on my facebook page. Kenneth Mayes. I will post it here as well as soon as my internet connection improves. It's sllllooooowoowwww right now.
