To create an opening in a work-top ?
This topic has been viewed 7106 times and has 12 replies
sree.arun.kr
Country: Kerala, Kerala, INDIA
Re: To create an opening in a work-top ?
Post by sree.arun.kr »
2D sinks are so nice when Normal mapping is possible.Because it is smooth and fast for rendering. But Normal maps are not works in SH3D now. [:(]
I wish,divide kitchen worktop in a way that each wall consist each part that the user can adjust according the room size. And let the user can add sink slab with his choice.
Feels if I don't understand this thread then plz ignore this comment. [#-o]
Very nice work, and I think your 2D compromise is a good idea, but admit I think the 3D models look a lot nicer and more in line with the quality of your models.
..25 x 10 = 250 possible combinations.... - clearly not sustainable...
For my own use, I add the sink to the worktop when I make the model - but then I only consider a few sinks and only use the 60cm modules and 3cm worktop. Even if you can add texture later, it would make for too many combinations.
I also once tried using a separate level for the worktop (room = worktop where floor thickness = worktop thickness). And while that let me use the staircase SVG cutout for the sink so I could move it on the worktop, the solution was a bit awkward (and could not be integrated in a furniture library).
So I guess the solution proposed by Hansmex is the most appealing.
PS You should also note that there once were slight differences in the models sold in the different countries, but I think kitchen models are now all uniform with the most recent modular system.
TNTDAVID
Post by TNTDAVID »
I have many different notices I am thus going to propose kitchen sinks in 2 versions in " 2D and 3D ".
The user will have the choice and will use the version which suits him best.
Thank you for your advice.
On www.composant-dynamique.com create the kitchen of your dreams.
