High priority Problem of executing the source code on eclipse
This topic has been viewed 14324 times and has 14 replies
choppyleo
Country: Yaounde, Cameroon
Post by choppyleo »
I followed the instructions on Readme but when I executed the program I obtain the error messages as shown below. Can someone advice me on what to do at this stage
Exception in thread "main" java.io.FileNotFoundException : -Djava.ext.dirs=C:\Windows\System32\lib\windows\i386;lib (La syntaxe du nom de fichier, de répertoire ou de volume est incorrecte)
at java.io.FileInputStream.open (Native Method )
at java.io.FileInputStream.<init>(Unknown Source)
at org.freehep.util.io.ASCII85InputStream.main
(ASCII85InputStream.java:147 )
Re: Problem of executing the source code on eclipse
You mixed up "Program arguments" and "VM arguments" in eclipse run configuration.
choppyleo
Post by choppyleo »
Thanks, I have corrected that and now seeing this:
Usage: ASCII85InputStream filename
sree.arun.kr
Country: Kerala, Kerala, INDIA
Post by sree.arun.kr »
Can you explain how to build runnable jar (sweethome3d.jar=2.55MB)or an exicutable jar(sweethome3D.jar=22MB)or sunflow.jar-0.07.3i?.
[* Don't know about programming not only java but downloaded apache-tomcat7.0.zip +ant1.94.zip +JDK1.7 but next step ...? ]
Intreasted to learn and tweak. [O:)]
Thanks in advance. [=D>]
choppyleo
Post by choppyleo »
I think I know how to creat that but I don't know how your reply is helpful to my question. Thanks
sree.arun.kr
Importing source and editing java code is success then now looking for a 10-20 step tutorial from a developer/programmer.
All kinds of tips are welcome. [=D>]
choppyleo
Post by choppyleo »
Please sree.arun.kr I don't get clearly what you are driving at cos I asked a question and maybe I don't understand you but I still don't see how your reply helpful to my question on trying to execute sh3d on eclipse. Thanks
sree.arun.kr
Question is simple
When I get the SH3D sourcecode then how to build a jar application using Eclipse.?
If you are successfull to create a sweethome3d.jar then share the methods you used.
Thats it. [=D>]
choppyleo
Post by choppyleo »
If you have already imported the source code on eclipse(but if not then follow the step of the Readme file).
After doing so then follow the steps on then site: http://www.wikihow.com/Create-an-Execut ... om-Eclipse
Good Luck
sree.arun.kr
Sourcecode importing and editing is done but exporting an exicutable jar is not enough successfull. Looks it need more tutorial about scripting. Anyway thanks for your help.(Your link is I already covered but thank you once again for sharing). Have a nice scripting[:)>-]
