I am trying to make a slanting parapet wall that joins at the corner and apply texture to it.
Made the parapet by using a sloping wall and using thiness as length and length as thickness. This makes the texture appear on the wrong side. Any help is appreciable.
If I could upload an image, would have been gr8.
Thanks in advance,
Jawaid
Making a slanting parapet and joining two of them at the corner
This topic has been viewed 4465 times and has 4 replies
iqbaljawaid138
Re: Making a slanting parapet and joining two of them at the corner
Jawaid,
A picture would be appreciated if you want an answer.
iqbaljawaid138
Thank You Mr. Hamsmex for the responce.
Being a newbee to this site I can't see direct image upload.
However here is the link.
For the first link (nw.jpg)I want the Edges to be Smooth as shown in the second link (example.jpg).
https://www.dropbox.com/s/y2gg8jzivwq55ji/nw.jpg
https://www.dropbox.com/s/bh5ckoud5e85lz2/Example.jpg
https://www.dropbox.com/s/vxwa12ttobv5qlw/Mumtywall.jpg
In the 3rd link, I wanted to bend the groove in the wall, to curve out on the top.
Thank you ,
Jawaid
Thank you ,
Jawaid
Jawaid,
This thread explains how you can share images.
This file shows a workaround for your parapet: parapet workaround
If this image shows more or less what you want to do, then you should use another program. SH3D is designed for interior decorating, not for professional architectural design. You will need a "real" 3D design program like Sketchup .
iqbaljawaid138
Thanks Hans,
Your Idea worked. Had to make slight adjustments but nice.
Will upload the .obj and the picture.
By the way I am not a professional. Its my home that I am trying to design.
Regards,
Jawaid
Regards,
Jawaid
