Hey, I seem to be having troubles saving my project when I add certain pictures as the material for a picture frame. I'm using the online version.
I get the errors-
RecorderException: Can't save home
java.io.IOException: Server returned HTTP response code: 500
I'm not much of a tec guy so I have no clue what this means...
Thanks for the help!
Save Problem
This topic has been viewed 2962 times and has 4 replies
KellyJesse
- Country: Orem, Utah, United States
Re: Save Problem
It could be because one of your two projects reached the size limit authorized on the server, i.e. 3 MB. Sorry, but I won't increase that value. If you need to import more textures, you'll have to export your project and use the installer version.
KellyJesse
Re: Save Problem
Awesome. thank you so much for the quick response!
Re: Save Problem
Hi! I might be running into the same problem, that I cannot save my home due to it is too large in the online version. If I export the sh3d file and install the software, can I open it with the installed version?
I do not want to turn off my computer as I do not want to lose 6-7 hours of work
I really like the progem!!! Thanks for it!
Re: Save Problem
Yes. While keeping your browser open, you can test it: download Sweet Home 3D installer, run the installer, open with it the file exported from the online version, then close the webpage of the online version.If I export the sh3d file and install the software, can I open it with the installed version?
