open side shed rendering
This topic has been viewed 6128 times and has 10 replies
scottsport
Hi all,
I want to use SH3D to draw and design an indoor equestrian arena that has:
1. A roof with support columns at regular intervals but otherwise is open sides and one end
2. At the other end a residence under the same roofline
3. The residence is elevated above ground level by 60cm with a verandah
I have drawn the residence - sans roof - but cannot figure out how to draw the rest of the arena.
Any help would be appreciated.
Thanks for a marvelous program as well. Certainly the best one out there so far as i can determine - and for free!
Re: open side shed rendering
Pretty hard to tell without more information. Is the roof the problem? (Flat roof = flat elevated box). Or the columns? (Use boxes shaped as columns). Draw a room for the arena to add texture. You probably need to use several levels.
scottsport
Thanks very much for the replies. I was a tad terse I suppose.
Hansmex : Yes that is the idea except that the horse part has no sides - only columns at regular intervals to support the roof, and the residence part starts at verandah level.
okh: Thanks - re arena - yes I think the 'furniture object' trick would look after the gable roof and the columns and setting up 2 levels (ground - verandah, and verandah - residence roof; which is the same roof line as for the arena) for the residence.
Again - great to have this support. I have only been using the software for a day so I have a lot to learn!
Tony Scott
Tony Scott
scottsport
I'll reply to me...
Now have the roof and columns! thanks so much for the tips. Here is what I have so far.
Just need to figure out how to add the verandah...
/Users/tonyscott/Documents/clermont planV2.png
Simple solution - verandah = room with low, thin walls.
PS - image link local - doesn't show
scottsport
Thanks heaps to all.
Hansmex, I cannot figure out how you gave the verandah a surface texture.
Could you elaborate please?
Thanks again.
tony
Thanks again.
tony
Please study the example file I gave you.
The veranda is just a room, and it's easy to gives rooms textures.
Read the User's Guide or use the in-built Help.
scottsport
BTW - here is my project thus far.
Still some work to do - adding the verandah roofs etc.
Any advice is always welcome
https://www.dropbox.com/s/4e0jiopj7tdqk ... 0copy.sh3d
Thanks again for this marvelous software.
tony
tony
scottsport
Thanks again, your file has the verandah as a room - how did you get the room to show a 'roof' which would be the same as a 'floor' from the POV of layer 1?
I may have be way over-conceptualizing this way too much of course...
