confused High priority Please Help...
This topic has been viewed 7162 times and has 8 replies
Ajarudin
Country: Nikava, Gujrat, India
Please Help...
Post by Ajarudin »
I want to make sloped roof on my designed house..
and how to make upper side rounded wall like this ..|^|..
where ^ is rounded
rkv104
Re: Please Help...
Post by rkv104 »
there is roof models package that has different types of roofs that you can use
http://www.mediafire.com/download/sk2mo ... roofs.sh3f
download and double click on file to install. and then restart sweethome3d ....then 'roof' category will be available furniture...select 'gable' roof for your purpose...i am assuming you know how to set height, width, angle etc...
cheers
rkv104
Re: Please Help...
Post by rkv104 »
oh sorry use 'circular' roof for your purpose...if you want rounded roof....
Re: Please Help...
where ^ is rounded
In addition to the excellent roofs proposed, you can also make a round wall in SH3D, export it to .obj format, re-import it and rotate it. And there is, of course, the slopingCeilingGuide by hansmex.
Re: Please Help...
Sorry, there's no direct way to create walls with a round shape at its top.
rkv104, your roof library looks nice. [:)]
Are you the one who proposed the same roofs in a 3D model ticket? Did you you design these roof shapes yourself?
rkv104
Re: Please Help...
Post by rkv104 »
No the library is not created by me...i found it following one of sweethome3d threads........
probably 'Krams036' is the creator of these wonderful roofs...
whosoever did it ...its a great help to all the users of sweethome3d ...
cheers,
rkv104
Re: Please Help...
Post by rkv104 »
i am not sure about licensing issues....if that's the case please do not use them....
rkv104
Re: Please Help...
Post by rkv104 »
i have deleted the file from above mentioned link...as licensing does not allow redistribution....guys make the rounded roof using half semi circular cylinder..rotated correctly....
Re: Please Help...
Some roofs amongst my mock-ups (category geometry). I will update the file (with proper cut-outs). Models made by me CC-BY. Basic roofs are fairly straightforward. Making a rounded roof, took less than 5 minutes:
  • Draw a wall the shape of your roof (as if the roof stands on its side).
  • Select wall and export selection to .obj format
  • Import and rotate.
See images below.
Your challenge in this case is making end walls with arched tops. (In the mock-up models above, you will find a half circle which could be used to cover the ends of your he roof when you first draw it.)
