Hi all, first of all thanks for making this awesome free 3D program, really grateful and congratulations!
I've been using it for over a week, trying to reproduce my apartment cause I'm going to do big changes on it and wanted to check furniture positions and what walls to change etc...
All perfect, 3D view working, renderings ok, when I move something in 2D map it moves in 3D view all perfect.
Until yesterday I saved and from now on no change from 2D map appear in the 3D view, but it happens JUST in one file, the one that I have all the house made... and put a lot of work in build it [:((]
More details:
- When I mode anything in the 2D view doesnt reflect in the 3D view.
- When I built a wall odd wall appear, only the start and the end of the wall, when I remove it, the wall still appear on 3D view oddly.
- When I save and reopen the file all appears in the correct changed position but again anything that I move on the 2D view doesn't appear in the 3D in the correct place.
Any idea?
I uploaded the file -> click here to download it.
THANKS FOR ANY HELP!
3D view not updating, previously worked perfectly.
This topic has been viewed 6903 times and has 7 replies
Re: 3D view not updating, previously worked perfectly.
I tried your file with version 4.2 but couldn't reproduce the issues you reported. From your explanations, it seems to be missing or delayed updates in the 3D view, and this means that at least, your file is not buggy and your work not lost.
Could you give more details about the operating system and Sweet Home 3D version you use?
Also using 4.2, in a Windows 7, tried to different computers both with Win 7 (Home & Work).
Here print screens:
- 3D view in the same WINDOW, grey, noting there in the 3Dview, image:
http://i.imgur.com/Xl0kVEh.jpg
- If I SPLIT the 3D View in another window, it works, image:
http://i.imgur.com/Iwv29uG.jpg
- I moved the chair in the left room, and draw two walls, the chair inst updated and the walls appear but oddly shapped, image:
http://i.imgur.com/C6IrVt2.jpg
Puybaret can u change any furniture around save the file and re-sended to me? lets see if this way it gets fixed for me.
THANKS! if u need some more information plz tell me.
Here print screens:
Please, check if it happens with the Java Web Start version too. If it's the case, activate the Java console, and report here the stack trace that might appear in the console when the update bug happens (a stack trace starts with Exception in thread…).
Java Web Start same stuff.
Here the LOG of console:
https://mega.co.nz/#!89pEAZxC!TKb_VHHLV ... cwhX4FK7fk
A lot of null pointer:
THANKS!
Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D$1$1.componentResized(Unknown Source) at java.awt.AWTEventMulticaster.componentResized(Unknown Source) at java.awt.AWTEventMulticaster.componentResized(Unknown Source) at java.awt.Component.processComponentEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$200(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue$4.run(Unknown Source) at java.awt.EventQueue$4.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)THANKS!
Thanks for this log. It looks like a few other ones I got recently bound to 3D view saved as detached. I just released a beta version that should fix it. Can you check please?
PERFECT! its solved.Looking forward the new version
Tested also with two screens.
Thanks a lot Puybaret.
Hello sir I'm using sweet home 3d since 5 days and I'm very impressed but i have the same problems. i couldn't download the beta version can you help me ?
