models
This topic has been viewed 3305 times and has 9 replies
models
Hi, I want to ask how can I change the color of my windows, the are two colored inside the are white and outside the are blue...
my second question is how can change 3d models like stairs...i can not add a pictures here to explane wath I want to change.
Re: models
1 - Use Furniture -> Modify -> Materials -> Modify to change colours.
2 - This message explains how you can use images.
Re: models
Thanks Hans for the repley I will post soon a picture ans explane my "problem" I'm going to do my windows first
With this I have a other question how can I add floors to my already finished home I forgot to add them in the beginning...
Re: models
Jean-Paul,
You can use Plan -> Add level to make more floors in your home.
Maybe you should read the User´s Guide, which covers all this basic stuff.
Re: models
In case you mean how to add a floor to the rooms so you can use a texture on them, you only need to select the "create rooms" tool and double click inside each room.With this I have a other question how can I add floors to my already finished home I forgot to add them in the beginning...
Re: models
Thanks Hans for the second reply....i'm going to add some pictures to explane my "problem"...
http://www.mediafire.com/view/16gk4bs44kof1dd/jp2.png
my house have three levels (bell etage) 0,1 and 2 level 0 is garage, level 1 is the living room and on level 2 are the bedrooms/bathroom so when you are on level 0 you see the stairs that goining to level 1 on the image the stairs is turning below and I would like to change it like on the next picture,turning on top;
http://www.mediafire.com/view/6djh1p47r ... .08.05.jpg
http://www.mediafire.com/view/ufb0dpf4f ... .43.23.jpg
When you go from level 1 to level 2 the stair is turning below and on top how can I change that...?
A other problem you can see on the next picture...how can I add the bevelled edge from the roof to the project and make visible to the 3d view..
and when you look close to the first image you can see I have no floors (vloeren) and seelings (plafonds) how can I fix that..
ok Hans and the others to I hope you can help me to solve this...
Re: models
thank for the reply...I will try later I let you know something..have a nice weekend.
Re: models
Sorry I have posted twice the same picture..this is the correct one;
http://www.mediafire.com/view/op3miintc ... .44.22.jpg (stair from level 1 to level 2)
Re: models
Jean-Paul,
stairs with quart turn at top
You will need to install Sketchup, load the model, then Export as 3D.
On the Documentation page you will find a tutorial explaining how you can make a dormer.
Please, read the User Guide to learn how to make floors and ceilings.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot]
