I have a 2-D complete drawing that is finished.
The thing is that I need to mirror¹ it and don't know how.
Please how do I do this?
¹) upper right corner will end up as upper left corner after mirroring.
Mirrored drawing
This topic has been viewed 2862 times and has 5 replies
[email protected]
- Country: Linköping, Sweden
- Contact:
Re: Mirrored drawing
Well, if you don't need to make changes after mirroring, then you can do this:
1) install (if not installed) the "copy as new furniture" plugin
2) select everything in your design, then use the "copy as new furniture" option
3) open a new document and paste the copied desing, which will appear as a single object
4) edit the object and mark "mirrored shape" checkbox
That's all.
That's all.
Rolf,
Download and read the Plug-in Tutorial. (here)
Download and install the Advanced Edit plug-in.
Use that plug-in to mirror your design, in such a way that you can still edit it.
Does Advanced Edit plugin mirror? I think it only rotates.Rolf,
No, it mirrors if you use a negative value for width or height. [;)]
Oh! I see. Well, you can always learn new things. [:)]No, it mirrors if you use a negative value for width or height. [;)]
