Hi!
Does someone know how to include insulation on the walls? I know that you can part the wall into two pieces (same width). But is there any way to get a wall for example with 25cm bricks and 20cm insulation?
Babsi
Insulation
This topic has been viewed 3472 times and has 1 replies
Re: Insulation
Babsi,
No, there's no simple way to do that.
However, you could draw double (or triple) walls, using exact coordinates, then use Modify walls -> Pattern in plan to distinguish between the walls.
Personally, I draw my cavity walls 30 cms thick, which is the standard in my country (10 cm outside wall, 10 cm cavity/insulation, 10 cm inside wall).
