Roof with transparent material
This topic has been viewed 8873 times and has 8 replies
mau67
Country: Como, Italy
Post by mau67 »
Dear, thanks for this spectacular software.
Just a question:
I need to made a roof (over patio)with wood structure and transparent (glass) roofing.
How can I do it ?
Thanks in advance.
Maurizio
Re: Roof with transparent material
Maurizio,
Look here.
Files with "transp" in the filename are boxes with transparency in different colours.
mau67
Post by mau67 »
Dear Hans thx thx thx , the transparent box was perfect.
But I've a little thing again..(sorry...): I need to put the wood structure (made from cube) and the trasp roofing, tilt down from wall to the garden.
Can you help me ?
Maurizio
hal9000
Country: Spain
Post by hal9000 »
Take a look at this tutorial:
http://www.sweethome3d.com/slopingCeilingGuide.pdf
In rough, you have to compose (or re-import) the object vertically, give the inclination as a rotation over Z axis (which is the only allowed in the plan editing), then export the rotated object and re-import it again rotating it so it's horizontal again.
mau67
Post by mau67 »
Hans....I will be crazy :-(
I'm not able to tilt the obj....ever and ever flat.
I've read the tutorial but I'dont found the right tip.
What can I do ?
Thank in advance, I'm sorry for the "torture".
Maurizio
mau67
Post by mau67 »
Ops ! Thanks to Hal :-)
I hope the text Hold the Shift key down while clicking on an arrow to rotate the model at smaller steps that is shown at the second step of the import wizard would have been helpful enough. [:(]
mau67
Post by mau67 »
Dear, the way is not easy but...that's ok.
Thanks to all
Rotation in the 3D space around 3 axes is never easy in all 3D software! [;)]
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Semrush [Bot]
