Hey to all Sweeters,
is it possible to do a global rotate?
For example, I have a complex home design and I would like to do something like:
Ctrl-A (to select all objects)
then rotate all the objects as being 1
I have tried the 'group furniture' but that doesn't do what i want...
thanks!
hp
Global rotate
This topic has been viewed 2534 times and has 3 replies
Re: Global rotate
Did you try the Home Rotator plugin?
HornyPotter
Re: Global rotate
Now i did!
i downloaded it... installed it... but it does not appear in the Plan menu... yes... i did quit and restarted SH3D... I'm running 4.0
Re: Global rotate
That's weird. Well, what language are you using? I'm using Spanish and in my case the "plan" menu is called "plano", but the plugin seems to ignore the localization and then it adds its own "plan" menu with the options to rotate, so I have two menus "plano" and "plan".
Anyway, this plugin allows 90 degrees rotations only, which I don't know if would be good for you or you need a more customizable angle.
