It may be an odd question (and maybe better suited to Sunflow's forum), but:
Does anyone experience low CPU usage during rendering ?
When I render, my CPU utilisation is at around 60% (javaw.exe process)
I thought it should be almost 100%, since Sunflow creates a thread for each core.
I've tested this on two machines:
- Core I7 860 (4 cores, 8 threads)
- Phenom II 950 (4 cores, 4 threads)
I'm wondering whether it's something funny about my machines (or my SH3D scene).
Anyone ?
Rendering does not use 100% CPU
This topic has been viewed 7073 times and has 4 replies
Re: Rendering does not use 100% CPU
What Java version do you use?
Could you try with the installer version and not the Java Web Start version, to see if it behaves the same?
Hi Emmanuel,
I've noticed it first with Beta 4.0 and JRE7, but before making this post I've downloaded standalone 3.7, and it happens there too.
Cheers
Cheers
Would you have any tool that would prevent a program to use all the CPU power?
Hi Emmanuel,
I haven't used SH3D for some time recently.
Now I've downloaded version 4.1 and voila ! The issue is gone.
It now uses 100% of CPU to render on my machine and renders almost twice as fast.
Cheers,
Cheers,
