Hi
Is there a way to insert (manually or programatically) new objects at a given position on a building plan ? I would like to be able to specify object position in cartezian coordonates (x,y,z) and to insert or remove this object in a building plan from my own program using an API.
thanks
Bogdan
Inserting objects at specified location in a building plan
This topic has been viewed 5032 times and has 4 replies
Re: Inserting objects at specified location in a building plan
HomePieceOfFurniture instances can be moved with their setX, setY and setElevation methods. But why programming something you can already do with the existing user interface?
I would like to use Sweet Home 3D for object tracking inside a building.
Then call the methods of HomePieceOfFurniture. The listeners that are already added to a piece will automatically update its location at screen if necessary.
Could you please provide an example of programmatically inserting and moving an object on the building plan ?
