This topic has been viewed 3874 times and has 7 replies
Thread status:
Active
mife
Posts: 5 Joined: Sun Jan 27, 2013 9:10 am
Post
by mife » Sun Jan 27, 2013 9:34 am
Hi there
is there a way to have something like framed pictures with different motives?
What I tried to emulate this:
- a wall with texture
Problem: You need for every height a new niveau
- a simple mirror model with texture
Problem: The texture starts from the middle
Any hint apriciated
Posts: 9440 Joined: Mon Nov 07, 2005 12:00 pm
Post
by Puybaret » Sun Jan 27, 2013 10:28 am
Are you sure you use the last version 3.7 or that you imported that texture in that version?
The issue with the misplaced texture you report looks like an other one that was fixed in version 3.4.
mife
Post
by mife » Sun Jan 27, 2013 12:29 pm
Version 3.7 Java version 1.6.0_37
Post
by Puybaret » Sun Jan 27, 2013 2:30 pm
Please [url=mailto:
[email protected] ]send me[/url] a SH3D file that contains only your object with its texture. I'll try to check the issue.
mife
Post
by mife » Sun Jan 27, 2013 3:58 pm
the texture is rendered upside down!?
mife
Post
by mife » Sun Jan 27, 2013 4:30 pm
best I could achieved
Picture as texture 70x50cm, 350x250px
Cube as model 70x50x50cm,
Drawback: Thickness has to height of texture
Post
by Puybaret » Sun Jan 27, 2013 5:42 pm
It works for me. Look at the file attached to this message.
Sorry, but keeping posting messages showing that it doesn't work for you without any SH3D file won't help me to fix a bug, in case you found one. [:(]
BoxWithTexture.sh3d
(109.06 KiB) Downloaded 1276 times
mife
Post
by mife » Fri Feb 01, 2013 2:15 pm
Thank you so much for your help
Your BoxWithTexture is it!
Awesome
