How to select all objects in all levels
This topic has been viewed 4266 times and has 8 replies
txwikinger
Post by txwikinger »
I have created a multi-level structure and would like to move all objects that are part of it. Hoow can I do this?
Re: How to select all objects in all levels
You can select all the lines in the furniture list at bottom left, and copy paste it if needed.
txwikinger
Yes, but I need to select all objects, not only furniture, i.e. also the walls and rooms from the other levels
It's not possible at this time. But I wonder why you need such a feature.
cnanu2000
Post by cnanu2000 »
It works for me.
I can select all or part of any object\s and copy paste to othe level floor.
I used it to copy exterior walls from one floor to other.
HTH
Nanu
cnanu2000, I guess txwikinger wants to select all objects in all levels at the same time. [;)]
I wouldn't mind to program this feature but as it will need some programming to show to the user that all levels are selected, I prefer to have some interesting use case before starting.
Jobil
Post by Jobil »
I have the same need. My use case is to design also the outdoors. So I would like to move the entire house in the building plot.
Thank you in advance
Jobil
cleveroff
Country: Latvia
Post by cleveroff »
I have the same need too. I have two seperated plans, one with house, another with bath-house. Both plans have many levels. Now I want to merge these plans in one file. Help!
cleveroff
Country: Latvia
Post by cleveroff »
Probably I understood, that it is impossible. Because the dimensions of levels in both plans are too different.
