Hi Guys,
When I import a new texture; in particular the one at the first link, importing via wizard goes ok. I choose 168 x 168 and it appears ok:
http://cl.ly/image/1s1O2f330u3o
When I use it in my home, it shows all wrong:
http://cl.ly/image/193h3v0R2n2c
Anybody got any clue what is going wrong with it?
Using Mac with SH3D 3.6; working great for the rest!
Tried to file a bug but don't have a userid there (yet)...
Grtz!
Texture import ok; showing later 'all wrong'....
This topic has been viewed 3573 times and has 3 replies
Re: Texture import ok; showing later 'all wrong'....
Ed,
This isn't a Mac bug, it's a problem in SH3D or in the Java-3D software it uses. The problem lies in the way
(a) the triangles on the surface of objects are applied or
(b) SH3D applies textures on a surface or
(c) a combination of the above.
The only workaround that I know, is to design a made-to-measure object using a different 3D program, or to make a thorough study of the OBJ "language" and learn how to apply the texture directly from within the OBJ code.
Try applying your texture to a box, then rotate the box to look at all sides. You'll see similar effects. I once managed to construct a box with correct textures on all vertical faces using the method described above. It wasn't easy.
Applying a texture on a cylinder or a tube doesn't work the same way as applying it on a cube.
If you want to apply your texture, please download the attached 3D model and replace the tube.jpg image it contains by yours using the same file name.
- Attachments
- tube.zip
- (6.32 KiB) Downloaded 526410 times
Oh wow, didn't realize 'things could be soo difficult'! hihihi
Thanks for your outstanding support; both Emmanuel AND Hans!
You guys AND this software amaze me each and every day really!
I'm going to apply the tube.zip later, Emmanuel; I understand your explanation!
Am addicted to this program really! I really love it!
