Hello guys!
I have just installed SW 3D and I am facing this problem so that I cannot even start drawing - while importing a backgroung image it is imported in a badly cropped way - actually a small piece of an original picture is available at the final stage.
Please help.
SH crops background image
This topic has been viewed 4356 times and has 3 replies
Re: SH crops background image
Did you correctly resize the background image using the scale option?
blackarrow
After doing some experiments I eventually came to a solution - the problem was a correct zero point 0:0 - once I manually inserted 0 and 0 in X and Y fields - the plan import was OK.
Hi there
For me ,i usually crop or process the image using a third party image tool .Because i am a beginner of image processing.And it would be more convenient for new users if they own a powerful image processing tool.There are many third party tool for image processing.They support to resize ,crop or convert image directly.So i think you can try to add one of them to help you out.Best wishes.
