How to use the applet viewer with multi-level houses?
This topic has been viewed 3526 times and has 4 replies
marchenar
Country: Bariloche, Rio Negro, Argentina
Post by marchenar »
Hello, I drew a two levels house, and I would like to know if it is any way to do the following things from the "applet viewer":
1.- Show/hide levels, or any way to see the lower level aerial view (using the aerial view I can only see the upper level covering the lower level). Using the editor I could select the level (using the tabs) and show/hide levels (using Ctrl+Shift+A and Ctrl+Alt+A), but I did find the way to do the same from the applet viewer.
2.- When I change to the virtual visitor viewer (using Space bar), the virtual visitor is in the lower level. Is there any way to move to the upper level using the applet viewer?
Thank you,
Roberto
Re: How to use the applet viewer with multi-level houses?
The viewer supports only the space bar to switch between aerial view and virtual visit.
If you want to go to the upper level, you'll have to use home and end keys to change elevation.
marchenar
Post by marchenar »
Hello, thanks for your response. I notice that the Home and End keys doesn't work on Applet Viewer, have you any other idea how to change the level using the Applet Viewer?
Austinic
Post by Austinic »
Hello, srry guyz to interfere, but I am new here, so wat is applet viewer?
THX :)
marchenar
Post by marchenar »
Hello Austinic,
The Applet Viewer is just an applet written in Java to view SH3D designs from a web browser.
Regards,
Roberto
