Wooden Beams, Roof Support etc. (Holzbalken etc.)
This topic has been viewed 8606 times and has 2 replies
macfrog
Country: Germany
Post by macfrog »
here is a short HowTo create objects like beams, wooden substructure in old houses and so on. This time we don't use the "Box".
the picture below shows the first step pretty clear: you create walls with the dimensions of the wanted structure, like 5 meters long and 20by20cm in thickness:
these "walls" can be exported as OBJ and then re-imported to the furniture library in SH3D, preferably in an own category to find it back easily. Make sure, you use proper dimensions and angle while importing!
macfrog
kbon
Country: DE
Re: Wooden Beams, Roof Support etc. (Holzbalken etc.)
Post by kbon »
Thanks :) I already did it this way for my roof rafters, figuring this would be the right way, after reading the "how to make a roof" tutorial :)
Just to make this tutorial complete (for starters who don't know about it): You need to "copy as new furniture" the walls first (sh3d plugin), paste it in a new home and then export
macfrog
Country: Germany
Post by macfrog »
Yes kbon,
i forgot to mention this :-)
otherwise you're creating a "floor" panel behind those beams...wouldn't like that ....
macfrog
