Changing colour/texture of PART of an object.
This topic has been viewed 6301 times and has 5 replies
ABRanka
Post by ABRanka »
Hello.
I'm wondering about a possibility of changing colour or texture of part of an object. For example: having a chair that is composed from red sit and metal base - now if I change it to e.g. white, both red and metal change. It would be great to get white sit and metal base in this case.
Is it / would it ever be possible?
Regards.
Re: Changing colour/texture of PART of an object.
It should be possible in a future version. Future will tell! [:)]
gap
Post by gap »
ey! this is that i would like in walls, i mean, a color base and add some stripes in other colour, or sofas with patterns, it'll be great.
will take longer the future are u talking about?
thankyou.
Lynn22
Post by Lynn22 »
For the chair, if you have it in OBJ format you could re-texture it in any 3D application.
For the wall, build your wall as 2 separate levels (if your wall is 3 m. high, build level 1 at 1 m. and level 2 at 2 m. and no floor in between), give level 1 a color and level 2 a striped texture ;o)
gap
Post by gap »
thanks a lot!!!
oxygen
Country: Saratov, Russia
Post by oxygen »
For changing textures of 3D-models I use a custom models and change their textures in Deep Exploration than import models into SH3D.
When I want to add some stripes or another saped objects to the walls, I take a cube or round and change their textures and dimensions (length, width, height) in SH3D and plase them next to the wall. It looks like in this picture:
KT Exclusive_Damasse 6 by pixie Xu, on Flickr
The base of the walls was made in decorative plaster texture, than decorative frames was added on the needed levels. Than I took cubes that comes with program by default and changed thair properties, placed them on needed level. For that cubes I took textures of a wallpaper an murals (the antic lion of Affresco).
