Sloped Walls question
This topic has been viewed 4247 times and has 6 replies
StylusPilot
Post by StylusPilot »
I see the newer versions contain the ability for sloped walls.
I have a House which is on a sloped block of land.
roughly 27 degree slope
How can I start a wall at point A
have it go 10m and have it end at point B on a 27 degree slope?
I have been unable to find a guide so far.
any assistance appreciated.
Re: Sloped Walls question
Maybe you could try the Math Forum ?
B must be tan(27°) x 10 = 5.1 m higher than A.
macfrog
Country: Germany
Post by macfrog »
Friends,
i believe he's looking for a solution to create a downwards sloping wall, with a leveled upper end and the floor on top....
macfrog
StylusPilot
Thanks for that, very productive.
now onto my question, where is the option in the GUI for these settings for a wall?
Friends,
macfrog
Yes, thank you your version makes more sense.
If you use the above formula to calculate the slope, you can then use (in this order)
- CopyAsNewFurniture (to eliminate the floor) (see plug-ins PDF),
- Export to OBJ format (to export the wall segment as a model) and
- Import furniture.
Make sure that during importation you rotate the wall segment 180 degrees, so that the sloping side ends up at the bottom.
For one horizontal or vertical wall, no need to install CopyAsNewFurniture plugin.
