sad High priority swh3d stops open production file
This topic has been viewed 4327 times and has 4 replies
choe
Post by choe »
All of a sudden swh3D refuses to open a file I'm working with. I'm, pretty desperate as I'm already running late with this project.
I enclose the error message I get when launching it app from the terminal
any help appreciated.
_______________
Error message
chroe@linuXin:~/Programme/SweetHome3D-3.4$ ./SweetHome3D
Exception occurred during event dispatching:
java.lang.IllegalArgumentException: moveColumn() - Index out of range
	at javax.swing.table.DefaultTableColumnModel.moveColumn(Unknown Source)
	at com.eteks.sweethome3d.swing.FurnitureTable$FurnitureTableColumnModel.updateModelColumns(Unknown Source)
	at com.eteks.sweethome3d.swing.FurnitureTable$FurnitureTableColumnModel.<init>(Unknown Source)
	at com.eteks.sweethome3d.swing.FurnitureTable.<init>(Unknown Source)
	at com.eteks.sweethome3d.swing.SwingViewFactory.createFurnitureView(Unknown Source)
	at com.eteks.sweethome3d.viewcontroller.FurnitureController.getView(Unknown Source)
	at com.eteks.sweethome3d.swing.HomePane.createCatalogFurniturePane(Unknown Source)
	at com.eteks.sweethome3d.swing.HomePane.createMainPane(Unknown Source)
	at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source)
	at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source)
	at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source)
	at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source)
	at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source)
	at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source)
	at com.eteks.sweethome3d.SweetHome3D$2.collectionChanged(Unknown Source)
	at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source)
	at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source)
	at com.eteks.sweethome3d.viewcontroller.HomeController$29.run(Unknown Source)
	at java.awt.event.InvocationEvent.dispatch(Unknown Source)
	at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
	at java.awt.EventQueue.access$000(Unknown Source)
	at java.awt.EventQueue$1.run(Unknown Source)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
	at java.awt.EventQueue.dispatchEvent(Unknown Source)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
	at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
	at java.awt.Dialog$1.run(Unknown Source)
	at java.awt.Dialog$3.run(Unknown Source)
	at java.awt.Dialog.show(Unknown Source)
	at java.awt.Component.show(Unknown Source)
	at java.awt.Component.setVisible(Unknown Source)
	at java.awt.Window.setVisible(Unknown Source)
	at java.awt.Dialog.setVisible(Unknown Source)
	at com.eteks.sweethome3d.swing.ThreadedTaskPanel.setTaskRunning(Unknown Source)
	at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1$1.run(Unknown Source)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
	at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
	at java.awt.EventDispatchThread.run(Unknown Source)
Re: swh3d stops open production file
Please send [url=mailto:[email protected]]me[/url] your file. I'll try to fix it.
likaroli
Country: Guatemala, Mixco, Guatemala
Post by likaroli »
hey i cant open my file can somebody help me :(
likaroli, thanks for sending your file. I fixed the problem in your file and sent you the correct file.
The issue was different from choe's one, and it came from a DAE file you imported with accentuated letters.
I didn't find how to reproduce the bug but found a way to avoid it in Sweet Home 3D.
Until next version is released, please remove accentuated letters from 3D models files before importing them.
likaroli, the bug you encountered is fixed in the version 3.7 I just released.
