Bay Window
This topic has been viewed 7858 times and has 7 replies
Bay Window
Could you please tell me where I can find 3D Bay Window with 90 degrees, sort of like a box window outside the wall. I could not find on the web...
Re: Bay Window
Re: Bay Window
Yes, I did. But I could not find the one angled back 90 degrees
Re: Bay Window
Can you show a picture of what you are looking for?
Re: Bay Window
Hi Hans, I have uploaded a picture to below : http://sourceforge.net/tracker/?func=de ... tid=784668
thanks
thanks
Re: Bay Window
This is more a room extension than a bay window, in my view. So, I would treat it as one by drawing walls and inserting windows. That way you can have a floor and ceiling as well. Note that you can stack two windows on top of each other, if the window configuration should closely match your picture.
bay window.sh3d
bay window.sh3d
Re: Bay Window
I'm not sure if it could work as I need to rise in floor level and lower the ceiling height in the window area in order to match the actual status. Let me try and update you later. Thx so much Hans.
fanyam
fanyam
Re: Bay Window
Fanyam,
There's a solution for everything.
1 - Use SH3D version 3.3 with the CopyAsNewFurniture plug-in installed.
2 - Design your "bay window"
3 - Use boxes for floor and ceiling
4 - Use CopyAsNewFurniture and then Export to OBJ format to export your window as a model.
5 - Use Import furniture to use your model.
