Rendering problem
This topic has been viewed 11989 times and has 21 replies
Re: Rendering problem
Your timezone / longitude values aren't homogeneous. At 11 AM in Taipei, it's dawn at a longitude/latitude set in Europe, and the result is correct for these parameters.
I also have render problems. Some pixel-error can be seen... Here:
https://rms-systems.homelinux.net/downl ... er/Pic.jpg
Quickmic,
Can you use a TRUSTED website to host your images?
Firefox refuses to open it.
I don't wanna pay für an official cerificat but you can ignore the warnings... Else use this:
http://www.megaupload.com/?d=G05R2AW0
You may want to have a look at www.mediafire.com ....
But even with the black spots, it's a VERY nice image!
devilbliss
Ah ok emmanuel, thanks! Sorry for overlooking the timezone values, im not familiar with those. But its really cool that you've incorporated the timezone values in rendering photos in the program.
devilbliss
Nice quickmic! where did you get the wooden planks that you used for your room? thanks!
It's an other reason why you should choose the default photo rendering dialog of Sweet Home 3D v 3. It uses some code able to best guest your longitude/latitude for your default time zone, but the older Advanced rendering plugin doesn't use it (and I don't think I will update this plug-in).Sorry for overlooking the timezone values, im not familiar with those.
Thats just normal textures. I loaded picture templates from the Web and modified them. The Trick is, that you must make sure that the Textures don't have borders if they are merged. -> If you found a nice picture, modify it by mirroring in any directions. Here are some of mine.Nice quickmic! where did you get the wooden planks that you used for your room? thanks!
[Note from moderator: removed link to quickmic's textures library since he's not sure they can be redistributed]
quickmic, I don't want to be boring and appreciate your will to share your findings, but did you check you have the right to redistribute these images before posting them?
