Hi, Is there a way of handling a ceiling that has heating ducts running under it? In this case, my basement has 1/3 of the height lower than the rest to accommodate the drop. If I set the walls at each end to the correct heights (splitting) I seem to confuse everything. I get sloping ceilings but of course I need squared surfaces.
i.e. -----|_____|----- if that makes sense.
Any ideas?
Martin
Ceiling with different levels
This topic has been viewed 2755 times and has 2 replies
Re: Ceiling with different levels
Martin,
There is a quick and easy way:
- Take a box, give it the right dimensions, and place it underneath the ceiling.
If you want a "real" ceiling to behave in such a way, you have to do a lot of work using
- a - extra walls, made invisible by using transparent textures (gives a bad result) or better
- b - the construction method for multiple level houses (PDF)
Thanks Hans, I thought I could rely on you for an answer.
