I'm using version 3.3 on Windows 7. I have looked for the following path :
C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\plugins
but under the Sweet Home 3D folder I have two other folders "work" and "recovery" along with "preferences.xml" and nothing for plugins.
Thanks for your help.
Can't find the plugin folder
This topic has been viewed 7838 times and has 7 replies
Re: Can't find the plugin folder
plugins folder is created if needed when the user installs a plug-in (the same behavior applies to furniture, textures and languages folders where sh3f, sh3t and sh3l files are stored). You can create it yourself if you want to.
Thanks for your answer Puybaret.
I created the plugins folder and put a test plugin I wrote (a JAR file), but it's not read by SH3D when I run it. So I downloaded some plugin to double check and it worked. However, that plugin had a ".sh3p" extension. What's the diffrenece between a JAR plugin and a .sh3p plugin and how do I make one?
Thanks.
Thanks.
I also tried to test with the VolumePlugin from the tutorial to make sure I get everything right, but in the PluginAction.execute() method eclipse can not resolve the call to getHome(). And indeed I couldn't see where that method is declared?
Thanks in advance.
Thanks in advance.
Ah, it's an inner class. Sorry.
I finished creating the VolumePlugin, exported to JAR, changed extension to sh3p and run. I got the message saying the plugin will work in the next run but there's nothing new in the menu
I solved the problem. I was exporting with the wrong options. Sorry for spamming.
