Create "upside-down" sloped walls
This topic has been viewed 5456 times and has 3 replies
Mitch
Post by Mitch »
I want to try to make a wall with a sloping side. I found the slope options in the Modify screen of a wall. But it seems I can only make sloped walls that are wide at the bottom and narrow at the top.
I can make a wall like this:
|XX\
|XXX\
|XXXX\
|XXXXX\
But I want something like this:
|XXXXX/
|XXXX/
|XXX/
|XX/
Is this possible?
Re: Create "upside-down" sloped walls
It's not possible.
But you can import a triangle placed beside a box to simulate the same thing.
Mitch,
Or you can draw the wall in its upright position, then use the CopyAsNewFurniture plug-in, then Export to OBJ format, then Import furniture and turn it 180 degrees during importing. See the Sloping roof manual (PDF) for more info on this workaround.
Mitch
Post by Mitch »
Thanks for the answers.
I tried the "triangle" approach and that worked fine.
