lights question
This topic has been viewed 11141 times and has 23 replies
Re: lights question
i tried color change at first and then tried texture change texture(by a white sample pic), for sure i try changing both sides to check it , i didnt get what u mean by 'in 3d view' ? i make changes after clicking the object on upper side of software(2d mode screen) any settings can be maked by right clickin on 3d view screen?? i dont see any settings about walls or objects, just sum light and transparecy settings in modify selection!!
Re: lights question
The 3D view is explained in the help and the user's guide.
An other idea : maybe you created two walls at the same place. Select the one you want to change, delete it and check if an other wall is still there.
Re: lights question
in 3d view screen there is no edit about walls, just light and brightness, i edit colors of wallas on 2d screen , right click on wall and modify walls!! aint that right, i choose white , it shows every color but not pure white, just a grey tone at last point
Re: lights question
There's no wall edit in the 3D view, but it's there where you can see the effect of changing wall color or texture.
You'll never get pure white unless you increase light power. If everything was pure white you wouldn't distinguish shapes.
Re: lights question
so how in this pic, walls have different tones of white?
http://www.sweethome3d.com/images/gallery2010/Mayer.jpg
Re: lights question
I think there's a misunderstanding about what you expect to appear in the 3D view. This image was computed with photo creation dialog at one of two best quality levels.
Please, please, read Sweet Home 3D user's guide from the beginning to the end. It's not so long, and you'll learn many basic features that will help you to better understand how Sweet Home 3D works.
Re: lights question
no,no,:D:D after arrangements of lighting of lambs, and ceiling lights NOT clicked, i m creating best result high quality of image of 3d view screen, of course 3d view is just screen, i m takin a high quality photo by advenced rendering photo plug in, i ve learned that from begining, just wallas dont change lighter than a matt grey!
Re: lights question
here is sample, ceiling ,left wall and right wall are at different 3 colors,includind pure white(right wall) but result is same in create photo selection?
Re: lights question
I tried using the Advanced Photo renderer with different wall colors: 2 are beige and one is blue. As you can see, the colors are very soft, you can hardly tell that the 2 beige walls have color.
My settings:
North is at 60, the time is about 1:20pm, Silk walls, ceiling, and floors is set to "off" but I did use the Silk rendering setting with ceiling, lamp, and sun checked off (meaning the box is checked). The power for the wall lights is set to 40%
My settings:
- Attachments
- Sweethome3dLvgRm.png (211.04 KiB) Viewed 4307123 times
Re: lights question
i really appreciate for your advice and sending sample with settings.here is the settings u gave, and the result pic, my problem is: i changed all walls color to beige but in aerial visit view and in result photo pic left wall always seem to gray, that gray color is about to make me crazy!!! any advice aboput that u have? and also do u use 16/9 setting or 3d view setting for the photo , i used 16/9 as u can see,and my lens is always default(if this is ok)..also, my room never seem natural-realy pic like...!!!!!!!! why??? where i m wrong at???? (north position is arranged for my home angle but it didnt work anyway which is not important now when im having problems with inside of home: walllls!!!!!
http://i11.photobucket.com/albums/a178/mcdost/8.png
