United States
no 3d in copy of drawing
I have a drawing where 3d works normal as expected, made a copy, made some modifications to the copy and can't get any 3d in the copy. I have moved the camera to a different room in the copy, however even if put the camera back in the same place as it was in the original I still get no 3d in the copy not sure what I should change in virtual visitor if anything
Re: no 3d in copy of drawing
Did you check the coordinates of the virtual visitor with the visitor modification pane, after a double click on it? And does the 3D view work correctly in Aerial view mode?
United States
ok, after closing doc and reopen it works, but don't know where are coordinates of virtual visitor? and don't know what is the visitor modification pane? I will check documentation and post back
