Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: no 3d in copy of drawing |
| Print at Sep 28, 2026, 3:21:20 PM | View all posts in this thread on one page |
| Posted by bbxrider at Sep 11, 2019, 2:25:41 AM |
no 3d in copy of drawing I have a drawing where 3d works normal as expected, made a copy, made some modifications to the copy and can't get any 3d in the copy. I have moved the camera to a different room in the copy, however even if put the camera back in the same place as it was in the original I still get no 3d in the copy not sure what I should change in virtual visitor if anything |
| Posted by Puybaret at Sep 11, 2019, 3:36:22 PM |
Re: no 3d in copy of drawing Did you check the coordinates of the virtual visitor with the visitor modification pane, after a double click on it? And does the 3D view work correctly in Aerial view mode? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bbxrider at Sep 12, 2019, 9:16:13 AM |
Re: no 3d in copy of drawing ok, after closing doc and reopen it works, but don't know where are coordinates of virtual visitor? and don't know what is the visitor modification pane? I will check documentation and post back |
| Posted by VeroniQ at Sep 12, 2019, 11:53:43 AM |
Re: no 3d in copy of drawing Hi bbxrider, 3D View > Modify virtual visitor Have a good day. |
| Posted by bbxrider at Sep 12, 2019, 11:13:59 PM |
Re: no 3d in copy of drawing thanks veroniQ, looks like you would some severe numbers in there to mess up the virtual viewer, like eyes elevation of like 40' |
Current timezone is GMT Sep 28, 2026, 3:21:20 PM |
