Total posts in this thread: 4
Previous Thread This topic has been viewed 4064 times and has 3 replies Next Thread
Radek_Fric
can´t run sh3D
I can´t run this program. I try everything maybe. First start screen of sweet home and fall. And then it´s create file - hs_err_pid1008.*
I think, that problem will be in Java script. I´m already installed version 1.6.0_03
I´m install Sweet Home on ohter computers - and any problem. Only on my computer.
Can You help me?
Thanks.
radekfric
all text in this file:
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x09efc964, pid=1008, tid=3084
# Java VM: Java HotSpot(TM) Client VM (1.6.0_03-b05 mixed mode, sharing)
# Problematic frame:
# C [extension15135.dll+0x5c964]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x053c7800): JavaThread "J3D-Renderer-1" [_thread_in_native, id=3084]
siginfo: ExceptionCode=0xc0000005, writing address 0x09f0e7dc
Registers:
EAX=0x00000076, EBX=0x00133676, ECX=0x0a20f4f0, EDX=0x09f0e7dc
ESP=0x0a20f270, EBP=0x0a20f300, ESI=0x0a20f2b4, EDI=0x09f0e701
EIP=0x09efc964, EFLAGS=0x00010202
Top of Stack: (sp=0x0a20f270)
0x0a20f270: 09efcc38 05d13fc0 09f0e7dc 001336c0
0x0a20f280: 00000000 00000000 00000000 00000000
0x0a20f290: 00000000 00000000 00000000 00000000
0x0a20f2a0: 00000000 00000000 00000000 00000000
0x0a20f2b0: 00000000 00000000 00000000 00000000
0x0a20f2c0: 00000000 00000000 00000000 00000000
0x0a20f2d0: 00000000 00000000 00000000 00000000
0x0a20f2e0: 00000000 00000000 00000000 00000000
Instructions: (pc=0x09efc964)
0x09efc954: 40 74 06 83 79 08 00 74 24 ff 49 04 78 0b 8b 11
0x09efc964: 88 02 ff 01 0f b6 c0 eb 0c 0f be c0 51 50 e8 d8
Stack: [0x0a1c0000,0x0a210000), sp=0x0a20f270, free space=316k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j javax.media.j3d.Win32NativeConfigTemplate3D.choosePixelFormat(JI[I[J)I+0
j javax.media.j3d.Win32NativeConfigTemplate3D.getBestConfiguration(Ljavax/media/j3d/GraphicsConfigTemplate3D;[Ljava/awt/GraphicsConfiguration;)Ljava/awt/GraphicsConfiguration;+116
j javax.media.j3d.NativePipeline.getBestConfiguration(Ljavax/media/j3d/GraphicsConfigTemplate3D;[Ljava/awt/GraphicsConfiguration;)Ljava/awt/GraphicsConfiguration;+5
j javax.media.j3d.Renderer.doWork(J)V+1466
j javax.media.j3d.J3dThread.run()V+19
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x053c7800 JavaThread "J3D-Renderer-1" [_thread_in_native, id=3084]
0x053ca400 JavaThread "J3D-MasterControl-1" [_thread_blocked, id=1016]
0x02bc2c00 JavaThread "J3D-NotificationThread" [_thread_blocked, id=1416]
0x02bc2000 JavaThread "J3D-TimerThread" [_thread_blocked, id=248]
0x053e7400 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=1200]
0x0592b800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=856]
0x0592f400 JavaThread "AWT-Shutdown" [_thread_blocked, id=2976]
0x0590c800 JavaThread "Thread-12" [_thread_in_native, id=3828]
0x054a4400 JavaThread "Image Fetcher 1" daemon [_thread_blocked, id=1916]
0x05486000 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=2808]
0x054f4000 JavaThread "TimerQueue" daemon [_thread_blocked, id=3840]
0x02be7000 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=3620]
0x02be4400 JavaThread "Image Fetcher 1" daemon [_thread_blocked, id=3012]
0x02bccc00 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=3388]
0x003d7000 JavaThread "DestroyJavaVM" [_thread_blocked, id=3800]
0x02bcac00 JavaThread "Javaws Secure Thread" [_thread_blocked, id=1668]
0x02bc9800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=1520]
0x02b6bc00 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=932]
0x02b54400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=540]
0x02b4f800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=4028]
0x02b4e400 JavaThread "Attach Listener" daemon [_thread_blocked, id=3240]
0x02b4d800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=860]
0x02b12800 JavaThread "Finalizer" daemon [_thread_blocked, id=2416]
0x02b0e000 JavaThread "Reference Handler" daemon [_thread_blocked, id=3836]
Other Threads:
0x02b0cc00 VMThread [id=2140]
0x02b55c00 WatcherThread [id=1196]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 960K, used 656K [0x1a9b0000, 0x1aab0000, 0x1b870000)
eden space 896K, 71% used [0x1a9b0000, 0x1aa4f898, 0x1aa90000)
from space 64K, 28% used [0x1aaa0000, 0x1aaa4a18, 0x1aab0000)
to space 64K, 0% used [0x1aa90000, 0x1aa90000, 0x1aaa0000)
tenured generation total 7184K, used 5754K [0x1b870000, 0x1bf74000, 0x269b0000)
the space 7184K, 80% used [0x1b870000, 0x1be0e970, 0x1be0ea00, 0x1bf74000)
compacting perm gen total 12288K, used 5229K [0x269b0000, 0x275b0000, 0x2a9b0000)
the space 12288K, 42% used [0x269b0000, 0x26ecb798, 0x26ecb800, 0x275b0000)
ro space 8192K, 62% used [0x2a9b0000, 0x2aeb14a8, 0x2aeb1600, 0x2b1b0000)
rw space 12288K, 52% used [0x2b1b0000, 0x2b7f7278, 0x2b7f7400, 0x2bdb0000)
Dynamic libraries:
0x00400000 - 0x00423000 C:\Program Files\Java\jre1.6.0_03\bin\javaw.exe
0x7c900000 - 0x7c9af000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f5000 C:\WINDOWS\system32\kernel32.dll
0x77dc0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e70000 - 0x77f02000 C:\WINDOWS\system32\RPCRT4.dll
0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll
0x7e360000 - 0x7e3f0000 C:\WINDOWS\system32\USER32.dll
0x77f10000 - 0x77f57000 C:\WINDOWS\system32\GDI32.dll
0x76370000 - 0x7638d000 C:\WINDOWS\system32\IMM32.DLL
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre1.6.0_03\bin\msvcr71.dll
0x6d7c0000 - 0x6da0a000 C:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll
0x76b30000 - 0x76b5d000 C:\WINDOWS\system32\WINMM.dll
0x6d310000 - 0x6d318000 C:\Program Files\Java\jre1.6.0_03\bin\hpi.dll
0x76be0000 - 0x76beb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d770000 - 0x6d77c000 C:\Program Files\Java\jre1.6.0_03\bin\verify.dll
0x6d3b0000 - 0x6d3cf000 C:\Program Files\Java\jre1.6.0_03\bin\java.dll
0x6d7b0000 - 0x6d7bf000 C:\Program Files\Java\jre1.6.0_03\bin\zip.dll
0x6d000000 - 0x6d1c3000 C:\Program Files\Java\jre1.6.0_03\bin\awt.dll
0x72fc0000 - 0x72fe6000 C:\WINDOWS\system32\WINSPOOL.DRV
0x77c00000 - 0x77c58000 C:\WINDOWS\system32\msvcrt.dll
0x774d0000 - 0x7760d000 C:\WINDOWS\system32\ole32.dll
0x5b250000 - 0x5b288000 C:\WINDOWS\system32\uxtheme.dll
0x73720000 - 0x73769000 C:\WINDOWS\system32\ddraw.dll
0x73b80000 - 0x73b86000 C:\WINDOWS\system32\DCIMAN32.dll
0x746f0000 - 0x7473b000 C:\WINDOWS\system32\MSCTF.dll
0x751a0000 - 0x751ce000 C:\WINDOWS\system32\msctfime.ime
0x6d250000 - 0x6d261000 C:\Program Files\Java\jre1.6.0_03\bin\deploy.dll
0x77a70000 - 0x77b05000 C:\WINDOWS\system32\CRYPT32.dll
0x77b10000 - 0x77b22000 C:\WINDOWS\system32\MSASN1.dll
0x7c9c0000 - 0x7d1d8000 C:\WINDOWS\system32\SHELL32.dll
0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
0x77110000 - 0x7719b000 C:\WINDOWS\system32\OLEAUT32.dll
0x44530000 - 0x445ff000 C:\WINDOWS\system32\WININET.dll
0x050c0000 - 0x050c9000 C:\WINDOWS\system32\Normaliz.dll
0x442b0000 - 0x442f5000 C:\WINDOWS\system32\iertutil.dll
0x44610000 - 0x44737000 C:\WINDOWS\system32\urlmon.dll
0x773c0000 - 0x774c3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
0x5d5a0000 - 0x5d63a000 C:\WINDOWS\system32\comctl32.dll
0x6d2b0000 - 0x6d303000 C:\Program Files\Java\jre1.6.0_03\bin\fontmanager.dll
0x71a90000 - 0x71aa7000 C:\WINDOWS\system32\ws2_32.dll
0x71a80000 - 0x71a88000 C:\WINDOWS\system32\WS2HELP.dll
0x6d570000 - 0x6d583000 C:\Program Files\Java\jre1.6.0_03\bin\net.dll
0x6d590000 - 0x6d599000 C:\Program Files\Java\jre1.6.0_03\bin\nio.dll
0x71a30000 - 0x71a70000 C:\WINDOWS\System32\mswsock.dll
0x76f10000 - 0x76f37000 C:\WINDOWS\system32\DNSAPI.dll
0x76fa0000 - 0x76fa8000 C:\WINDOWS\System32\winrnr.dll
0x76f50000 - 0x76f7d000 C:\WINDOWS\system32\WLDAP32.dll
0x76fb0000 - 0x76fb6000 C:\WINDOWS\system32\rasadhlp.dll
0x698b0000 - 0x69908000 C:\WINDOWS\system32\hnetcfg.dll
0x71a70000 - 0x71a78000 C:\WINDOWS\System32\wshtcpip.dll
0x0ffd0000 - 0x0fff8000 C:\WINDOWS\system32\rsaenh.dll
0x769b0000 - 0x76a64000 C:\WINDOWS\system32\USERENV.dll
0x67270000 - 0x672c4000 C:\WINDOWS\system32\netapi32.dll
0x10000000 - 0x1000e000 C:\Documents and Settings\fric\Local Settings\Temp\extension15138.dll
0x5f210000 - 0x5f2dc000 C:\WINDOWS\system32\OPENGL32.dll
0x61ae0000 - 0x61b01000 C:\WINDOWS\system32\GLU32.dll
0x69000000 - 0x692eb000 C:\WINDOWS\system32\vticd.dll
0x6d3e0000 - 0x6d3e6000 C:\Program Files\Java\jre1.6.0_03\bin\jawt.dll
0x09ea0000 - 0x09f73000 C:\Documents and Settings\fric\Local Settings\Temp\extension15135.dll
0x4fd70000 - 0x4ff16000 C:\WINDOWS\system32\d3d9.dll
0x6df10000 - 0x6df16000 C:\WINDOWS\system32\d3d8thk.dll
0x77bf0000 - 0x77bf8000 C:\WINDOWS\system32\VERSION.dll
0x74c50000 - 0x74c7c000 C:\WINDOWS\system32\OLEACC.dll
0x76060000 - 0x760c5000 C:\WINDOWS\system32\MSVCP60.dll
0x6d450000 - 0x6d474000 C:\Program Files\Java\jre1.6.0_03\bin\jpeg.dll
0x6d1f0000 - 0x6d21f000 C:\Program Files\Java\jre1.6.0_03\bin\cmm.dll
VM Arguments:
jvm_args: -Xbootclasspath/a:C:\Program Files\Java\jre1.6.0_03\lib\javaws.jar;C:\Program Files\Java\jre1.6.0_03\lib\deploy.jar -Djava.security.policy=file:C:\Program Files\Java\jre1.6.0_03\lib\security\javaws.policy -DtrustProxy=true -Xverify:remote -Djnlpx.home=C:\Program Files\Java\jre1.6.0_03\bin -Djnlpx.remove=true -Xmx192m -Djnlpx.heapsize=NULL,192m -Djnlpx.splashport=1314 -Djnlpx.jvm="C:\Program Files\Java\jre1.6.0_03\bin\javaw.exe"
java_command: com.sun.javaws.Main C:\DOCUME~1\fric\LOCALS~1\Temp\javaws2
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH=.;C:\Program Files\QuickTime\QTSystem\QTJava.zip
PATH=C:\Program Files\Java\jre1.6.0_03\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\QuickTime\QTSystem\;PIXIEHOME\bin;C:\Program Files\Common Files\GTK\2.0\bin;"C:\Program Files\Java\jre1.6.0_03\bin";"C:\Program Files\Java\jre1.6.0_03\bin"
USERNAME=fric
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 14 Stepping 8, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 1 (1 cores per cpu, 1 threads per core) family 6 model 14 stepping 8, cmov, cx8, fxsr, mmx, sse, sse2, sse3
Memory: 4k page, physical 981100k(388848k free), swap 2368696k(1904056k free)
vm_info: Java HotSpot(TM) Client VM (1.6.0_03-b05) for windows-x86, built on Sep 24 2007 22:24:33 by "java_re" with unknown MS VC++:1310
[Feb 8, 2008, 12:14:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Heather_Bell
Re: Fatal Error... update from original poste
If anyone is interested, after searching again through these posts, I realized I had overlooked a comment by the developer that mentioned updating the video card driver. Unfortunately, my old Dell laptop has its own issues with video card drivers in Linux, and if anyone knows how I could get above the 810 driver and (hopefully) be able to use Sweet Home 3D again, that would be great.
In the meantime, I was wondering what a recommended amount of memory to be allocated to the card would be? I set it at 300k, should this be enough to run the application?
Thanks for any help given...HB
[Feb 9, 2008, 1:49:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry if I'm not able to help you more than that, but I don't master video card drivers configurations.
Anyway allocating 300k to the video card is probably not enough.
If you know Java, maybe you could checkout the project and use Java 3D 1.3.1 instead of Java 3D 1.5.1 library.
[Feb 10, 2008, 8:42:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: can´t run sh3D
Sorry for this problem. It's probably a problem with your video card driver as described in bug #1811441 https://sourceforge.net/tracker/index.php?fun...id=152568&atid=784665
Once Java 3D team will have succeeded to fix this problem, Sweet Home 3D will be able to warn you about this problem in a clean way, at least.
[Feb 10, 2008, 8:52:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
