Total posts in this thread: 6
Previous Thread This topic has been viewed 4334 times and has 5 replies Next Thread
Oak
Can't Run Sweet Home 3D
Both the web version and installation does not work for me:
Web:
http://sweethome3d.sourceforge.net/SweetHome3D.jnlp does not have execute permission ... please fix
Local installation on OpenSUSE 10.3:
@linux:~/Sys/Install/SweetHome3D-1.2> ./SweetHome3D
java: xcb_xlib.c:52: xcb_xlib_unlock: Assertion `c->xlib.lock' failed.
./SweetHome3D: line 1: 16934 Neúspěšně ukončen (SIGABRT) jre1.6.0_03/bin/java -classpath lib/SweetHome3D.jar:lib/Loader3DS1_2.jar:lib/itext-2.0.4.jar:lib/j3dcore.jar:lib/j3dutils.jar:lib/vecmath.jar:jre1.6.0_03/lib/javaws.jar -Djava.library.path=lib -Xmx192m com.eteks.sweethome3d.SweetHome3D
...this problem persist even after updating to lates Java 1.6.0.
Any suggestions?
Regards,
Oak
[Jan 18, 2008, 10:35:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Oak
Re: Can't Run Sweet Home 3D
Resolved the web start issue:
# su
(or sudo)
# ln /usr/lib/jvm/java-1.6.0.u1-sun-1.6.0.u1/jre/bin/javaws /usr/bin/javaws
...and then run:
javaws http://sweethome3d.sourceforge.net/SweetHome3D.jnlp
...and it works!
The original javaws had 0kb size. That was probably the problem.
Please, help me to resolve the intall issue.
Regards,
Oak
[Jan 18, 2008, 11:00:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Oak
Now, the web version says:
3D Error
Sweet Home 3D will exit now because of a fatal error in 3D rendering system.
Regards,
Oak
[Jan 18, 2008, 11:02:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The "fatal error in 3D rendering system" means that you have to upgrade your video card driver.
Sorry, I can't you tell you more than that...
[Jan 18, 2008, 11:09:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Randal_Lovelace
This error CAN NOT be a video card driver issue as I get the same issue and have the latest (nightly updated) drivers for EVERYTHING on my system. - This error needs fixing as it is apparent that a lot of individuals running different OS are getting this error.
[Mar 8, 2008, 12:18:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Randal_Lovelace
[root@localhost randal]# ln /usr/lib/jvm/java-1.6.0.u1-sun-1.6.0.u1/jre/bin/javaws /usr/bin/javaws
ln: accessing `/usr/lib/jvm/java-1.6.0.u1-sun-1.6.0.u1/jre/bin/javaws': No such file or directory
hmm no such thing here... interesting...
[Mar 9, 2008, 6:17:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
