Previous Thread This topic has been viewed 7890 times and has 10 replies Next Thread
Vuemme43
Italia
Single-glazed glass door for a store
I can not find the SweetHome 3D model of the single-glazed glass door for access to a store, can you help me?
[Jan 21, 2019, 10:08:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Single-glazed glass door for a store
Buongiorno!
I often use this one.
[Jan 21, 2019, 10:26:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You find some door models in the SH3D Sourceforge repository (a couple of glass ones too). Or, 3D warehouse search for glass door.
PS - an experimental, simple door with hinges in SF 3D models 508.
[Jan 21, 2019, 10:26:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bubblobill
Australia
Glass-Door.zip
I made this.
Enjoy
[May 4, 2019, 5:12:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you for sharing the door Bill, i do like the way you have set up the handles, unfortunately, there is a gap between the frame and the door, when positioned in a wall sweet home 3d will fill that gap with wall, 2 other points of less importance, it is only 800mm tall and it is needs to be imported as a door.
I noticed the issue with the gap because i have done the same sad.
Good luck and hope to see more.
[May 4, 2019, 7:34:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bubblobill
Australia
Hmmm... I put the air gap in on purpose for accuracy. I suppose I shall just have to take it out.
The whole unit is supposed to be 80" tall based on a commercial spec I found somewhere. Resize to 203cm for correct sizing.
[May 5, 2019, 4:12:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bubblobill
Australia
New link to file. Closed air gaps between frame and door as suggested by Mike53.
Glass-Door.zip
[May 5, 2019, 4:23:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bubblobill
Australia
Updated again. Now has a threshhold
Glass-Door.zip
[May 6, 2019, 8:13:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bubblobill
Australia
I declare this to be the last version I can be bothered with. I even added swing area and stuff.
Enjoy
Glass-Door.sh3f
[May 7, 2019, 9:47:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Better, but wall still visible, threshold slight issue, flickering, opaque? Even added to library it is still an object not a door, reopen with furniture editor and define as door
MIke smile
[May 7, 2019, 7:30:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
