Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Single-glazed glass door for a store |
| Print at Sep 20, 2026, 4:18:52 AM |
| Posted by Vuemme43 at Jan 21, 2019, 10:08:03 AM |
Single-glazed glass door for a store I can not find the SweetHome 3D model of the single-glazed glass door for access to a store, can you help me? |
| Posted by VeroniQ at Jan 21, 2019, 10:26:39 AM |
Re: Single-glazed glass door for a store Buongiorno! I often use this one. |
| Posted by okh at Jan 21, 2019, 10:26:55 AM |
Re: Single-glazed glass door for a store You find some door models in the SH3D Sourceforge repository (a couple of glass ones too). Or, 3D warehouse search for glass door. ok PS - an experimental, simple door with hinges in SF 3D models 508. ![]() |
| Posted by Bubblobill at May 4, 2019, 5:12:06 PM |
Re: Single-glazed glass door for a store![]() Glass-Door.zip I made this. Enjoy |
| Posted by Mike53 at May 4, 2019, 7:34:25 PM |
Re: Single-glazed glass door for a store Thank you for sharing the door Bill, i do like the way you have set up the handles, unfortunately, there is a gap between the frame and the door, when positioned in a wall sweet home 3d will fill that gap with wall, 2 other points of less importance, it is only 800mm tall and it is needs to be imported as a door. I noticed the issue with the gap because i have done the same .Good luck and hope to see more. Mike |
| Posted by Bubblobill at May 5, 2019, 4:12:51 AM |
Re: Single-glazed glass door for a store Hmmm... I put the air gap in on purpose for accuracy. I suppose I shall just have to take it out. The whole unit is supposed to be 80" tall based on a commercial spec I found somewhere. Resize to 203cm for correct sizing. |
| Posted by Bubblobill at May 5, 2019, 4:23:51 AM |
Re: Single-glazed glass door for a store New link to file. Closed air gaps between frame and door as suggested by Mike53. Glass-Door.zip |
| Posted by Bubblobill at May 6, 2019, 8:13:56 AM |
Re: Single-glazed glass door for a store Updated again. Now has a threshhold Glass-Door.zip |
| Posted by Bubblobill at May 7, 2019, 9:47:45 AM |
Re: Single-glazed glass door for a store I declare this to be the last version I can be bothered with. I even added swing area and stuff. Enjoy Glass-Door.sh3f |
| Posted by Mike53 at May 7, 2019, 7:30:11 PM |
Re: Single-glazed glass door for a store Better, but wall still visible, threshold slight issue, flickering, opaque? Even added to library it is still an object not a door, reopen with furniture editor and define as door ![]() MIke ![]() |
Current timezone is GMT Sep 20, 2026, 4:18:52 AM |
