Total posts in this thread: 6
Previous Thread This topic has been viewed 4864 times and has 5 replies Next Thread
grrrlgeek
usa
Partly tiled walls
Hi, I know I saw the answer to this somewhere in a forum post, but I can't find it now. How do I texture a wall that has tiles halfway up, then paint the rest of the way? TIA
[Dec 9, 2018, 8:43:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Partly tiled walls
- Modify walls - set colour/texture of wall (top part)
- Modify walls- Modify baseboards - set height and colour/texture of baseboard
[Dec 9, 2018, 8:56:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
grrrlgeek
usa
The wall already has a baseboard. So I need a baseboard, tile halfway up, then painted the rest of the way. I think it had something to do with creating a wainscoting, but I'm not sure how I'd do that.
[Dec 17, 2018, 1:00:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
In that case... The easiest thing to do is probably using a very thin box that you stick to the wall
[Dec 17, 2018, 1:23:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
grrrlgeek
usa
I did it with the high baseboards as you suggested. It's not a big deal in that room.
[Dec 17, 2018, 2:15:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You are right, there are quite a few posts about this. Using a high baseboard as 'wainscoting' may be the easiest way. Not too fond of using thin boxes, because they are always in the way when adjusting the wall or adding fixtures. For completeness of the thread, there is a third way: using a texture the height of the wall.
(see SF 346)
[Dec 17, 2018, 9:15:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
