Total posts in this thread: 5
Previous Thread This topic has been viewed 1822 times and has 4 replies Next Thread
Larz2
Top category library
Hello,
I have built a new furniture library with a new name. How can I make this library be current / top category, when opening SH3D?
As it is now, the current category is "All" (Preference setting: Furniture catalog view: Searchable list).
Thanks in advance!
(SH3D version 6.0 on Windows 7)
[Dec 3, 2018, 11:19:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Top category library
This can’t be changed.
[Dec 4, 2018, 1:22:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Larz2
OK thanks Puybaret.
Is it possible to delete or remove libraries, which will not be used, from the category list?
[Dec 4, 2018, 11:38:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
The "category" are parts in a "library".
In furniture window You see only the category from all installed libraries.
You could do one of this:
-remove the entire library from home folder (including those with pieces You need)
-edit the PluginFurnitureCatalog.properties files in every library.(e.g. I have 50+)
Anyway almost everything is possible if You relay want (not all are easy).
[Dec 5, 2018, 7:03:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Larz2
Thank you for your tip Dorin, I will try to edit the list of libraies.
Best regards,
Lars
[Dec 8, 2018, 10:08:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
