Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Top category library |
| Print at Sep 20, 2026, 12:25:51 AM | View all posts in this thread on one page |
| Posted by Larz2 at Dec 3, 2018, 12:19:57 PM |
Top category library Hello, I have built a new furniture library with a new name. How can I make this library be current / top category, when opening SH3D? As it is now, the current category is "All" (Preference setting: Furniture catalog view: Searchable list). Thanks in advance! (SH3D version 6.0 on Windows 7) |
| Posted by Puybaret at Dec 4, 2018, 2:22:54 AM |
Re: Top category library This can’t be changed. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Larz2 at Dec 4, 2018, 12:38:19 PM |
Re: Top category library OK thanks Puybaret. Is it possible to delete or remove libraries, which will not be used, from the category list? |
| Posted by dorin at Dec 5, 2018, 8:03:46 PM |
Re: Top category library The "category" are parts in a "library". In furniture window You see only the category from all installed libraries. You could do one of this: -remove the entire library from home folder (including those with pieces You need) -edit the PluginFurnitureCatalog.properties files in every library.(e.g. I have 50+) Anyway almost everything is possible if You relay want (not all are easy). ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Larz2 at Dec 8, 2018, 11:08:20 AM |
Re: Top category library Thank you for your tip Dorin, I will try to edit the list of libraies. Best regards, Lars |
Current timezone is GMT Sep 20, 2026, 12:25:51 AM |
