Posts: 31   Pages: 4   [ Previous Page | 1 2 3 4 ]
Previous Thread This topic has been viewed 42005 times and has 30 replies Next Thread
c0d3z3r0
Re: massive color-difference
Ok... it was easier to fix than expected \o/
Patch:
diff --git a/SweetHome3D/src/com/eteks/sweethome3d/j3d/PhotoRenderer.java b/SweetHome3D/src/com/eteks/sweethome3d/j3d/PhotoRenderer.java
index c95e11a94..56ca69c87 100644
--- a/SweetHome3D/src/com/eteks/sweethome3d/j3d/PhotoRenderer.java
+++ b/SweetHome3D/src/com/eteks/sweethome3d/j3d/PhotoRenderer.java
@@ -1273,7 +1273,8 @@ public class PhotoRenderer extends AbstractPhotoRenderer {
if (material != null) {
Color3f color = new Color3f();
material.getDiffuseColor(color);
- this.sunflow.parameter("color", null, new float [] {color.x, color.y, color.z});
+ this.sunflow.parameter("color", null, new float [] {(float)Math.pow(color.x, 2.2f),(float)Math.pow(color.y, 2.2f),(float)Math.pow(color.z, 2.2f)
this.sunflow.shader(appearanceName, "mirror");
} else if (texture != null) {
@@ -1321,7 +1322,7 @@ public class PhotoRenderer extends AbstractPhotoRenderer {
material.getSpecularColor(color);
float [] specularColor = new float [] {
- (float)Math.sqrt(color.x) / 2, (float)Math.sqrt(color.y) / 2, (float)Math.sqrt(color.z) / 2};
+ (float)Math.sqrt((float)Math.pow(color.x, 2.2f)) / 2, (float)Math.sqrt((float)Math.pow(color.y, 2.2f)) / 2, (float)Math.sqrt((float)Math.pow(color.z, 2.2f)) / 2};
this.sunflow.parameter("specular", null, specularColor);
this.sunflow.parameter("glossyness", (float)Math.pow(10, -Math.log(shininess) / Math.log(5)));
this.sunflow.parameter("samples", 1);
@@ -1340,7 +1341,7 @@ public class PhotoRenderer extends AbstractPhotoRenderer {
- float [] diffuseColor = new float [] {color.x, color.y, color.z};
+ float [] diffuseColor = new float [] {(float)Math.pow(color.x, 2.2f),(float)Math.pow(color.y, 2.2f),(float)Math.pow(color.z, 2.2f)};
TransparencyAttributes transparencyAttributes = appearance.getTransparencyAttributes();
if (transparencyAttributes != null
@@ -1373,7 +1374,7 @@ public class PhotoRenderer extends AbstractPhotoRenderer {
if (silk) {
@@ -1394,7 +1395,7 @@ public class PhotoRenderer extends AbstractPhotoRenderer {
if (coloringAttributes != null) {
coloringAttributes.getColor(color);
+ this.sunflow.parameter("color", null, new float [] {(float)Math.pow(color.x, 2.2f),(float)Math.pow(color.y, 2.2f),(float)Math.pow(color.z, 2.2f)});
} else {
this.sunflow.parameter("color", null, new float [] {0, 0, 0});
diff --git a/SweetHome3D/src/com/eteks/sweethome3d/j3d/YafarayRenderer.java b/SweetHome3D/src/com/eteks/sweethome3d/j3d/YafarayRenderer.java
index b0a3e69e5..97da951e6 100644
--- a/SweetHome3D/src/com/eteks/sweethome3d/j3d/YafarayRenderer.java
+++ b/SweetHome3D/src/com/eteks/sweethome3d/j3d/YafarayRenderer.java
@@ -1439,7 +1439,7 @@ public class YafarayRenderer extends AbstractPhotoRenderer {
- params.put("mirror_color", new float [] {color.x, color.y, color.z, 1});
+ params.put("mirror_color", new float [] {(float)Math.pow(color.x, 2.2f),(float)Math.pow(color.y, 2.2f),(float)Math.pow(color.z, 2.2f), 1});
params.put("specular_reflect", 1f);
createMaterial(appearanceName, params, new ArrayList<Map<String, Object>>());
@@ -1604,32 +1604,32 @@ public class YafarayRenderer extends AbstractPhotoRenderer {
float transparency = 1 - transparencyAttributes.getTransparency();
params.put("type", "glass");
params.put("fake_shadows", true);
- params.put("filter_color", new float [] {color.x, color.y, color.z, 1});
+ params.put("filter_color", new float [] {(float)Math.pow(color.x, 2.2f),(float)Math.pow(color.y, 2.2f),(float)Math.pow(color.z, 2.2f), 1});
params.put("transmit_filter", transparency);
} else if (material.getLightingEnable()) {
float shininess = material.getShininess();
if (shininess > 1) {
if (silk) {
- params.put("diffuse_color", new float [] {color.x, color.y, color.z, 1});
+ params.put("diffuse_color", new float [] {(float)Math.pow(color.x, 2.2f),(float)Math.pow(color.y, 2.2f),(float)Math.pow(color.z, 2.2f), 1});
params.put("diffuse_reflect", 1.5f);
- params.put("color", new float [] {color.x, color.y, color.z, 1});
+ params.put("color", new float [] {(float)Math.pow(color.x, 2.2f),(float)Math.pow(color.y, 2.2f),(float)Math.pow(color.z, 2.2f), 1});
params.put("glossy_reflect", shininess / 256f);
params.put("exponent", 100f);
params.put("type", "glossy");
} else {
params.put("specular_reflect", shininess / 512f);
params.put("type", "shinydiffusemat");
} else {
} else {
params.put("type", "light_mat");
if (lightPower >= 0) {
params.put("power", lightPower * 100);
@@ -1641,7 +1641,7 @@ public class YafarayRenderer extends AbstractPhotoRenderer {
} else {
params.put("color", new float [] {0, 0, 0, 1});
[Dec 27, 2024, 10:21:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
