Total posts in this thread: 6
Previous Thread This topic has been viewed 7869 times and has 5 replies Next Thread
enkonyito
Video format data
Following this , I wanted to test the addition of the Speed and Frame rate fields in the video panel.
I kept the original VideoFormat constructor by replacing the predefined frameRate.
new VideoFormat(VideoFormat.JPEG, new Dimension(Width, Height), Format.NOT_SPECIFIED, Format.byteArray, Format.NOT_SPECIFIED)
I modified the getVideoFormat method for which the videoFormat.getFrameRate() value is not taken into account because it is directly retrieved from the new Frame rate field.
When I play a video, the change in frame rate is perceptible but the value of the recorded data is set at 15 frames/sec.
video test_SH3D-6.0beta_320x240 pixels - 4-3 - 25 frames-seconde.mov
video test_SH3D-6.0beta_320x240 pixels - 4-3 - 50 frames-seconde.mov
EnkoNyito
[Oct 1, 2018, 7:20:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svedel77
+45 Denmark
Re: Video format data
If this is getting to work, I'll be so happy!
[Oct 1, 2018, 5:28:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Matthenry3
Bangladesh
Looks good. Hope this will work perfectly.
[Oct 1, 2018, 6:18:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
By creating a new instance,
videoFormat = new VideoFormat(VideoFormat.JPEG, new Dimension(videoFormat.getSize().width, videoFormat.getSize().height), Format.NOT_SPECIFIED, Format.byteArray, controllerFrameRate)
the frame rate is updated with each change and the correct value appears in the recorded video data.
userGuideExample_SH3D-6.0beta_speed 0.5x_frame rate 60_PVR-1.6betaTest
Regarding the Speed field, the value is expressed in factor as for most video players/editors. Normal speed (1.0x) is the default speed of SH3D.
Its value change is taken into account when the play/pause button is pressed.
EnkoNyito
[Oct 4, 2018, 12:20:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
confused Re: Video format data
Did you test this path in quality 3 or 4 ?
If yes, what was the calculation time ?
[Oct 4, 2018, 8:40:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pabloab
I tweak the old .mov to be upscaled, slower, and in h264 .mp4, WhatsApp shareable.
#!/usr/bin/env bash
for file in *.mov; do
scale_factor="2"
slow_factor="4"
ffmpeg -y \
-i "${file}" \
-c copy \
-an \
-vf scale=iw*${scale_factor}:ih*${scale_factor} \
-filter:v "setpts=${slow_factor}*PTS" \
-c:v libx264 -profile:v baseline -level 3.0 -pix_fmt yuv420p \
"${file%.*}_h264.mp4"
# -stream_loop 3 \
done
[Feb 23, 2023, 6:29:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
