Italy
Roofs
In my opinion, a nice feature that Sweethome3D could provide is the possibility of creating a roof. An option similar to creating a floor or wall but that creates a roof based on the size you choose, as usual.
In this way the current creation of the roof, which requires particular time, would be simpler, like everything that can currently be done with SH3D.
Re: Roofs
..difficult to implement this feature into sh3d?
I agree it would be nice to get a roof automatically. At least if it were exactly the kind of roof I wanted. I would not know about the programming bit, but I have come across house planning programs where the roofs would not work properly for anything but very simple projects. And even then, the overhang and the joints became strange. So, at the end of the day, I kind of prefer SH3D where you can fit a model roof...
Actually, just like you made nice roofs on your Mini Cottage already.
Re: Roofs
As UbuntyBirdy says, and as with most roofs, the model is quite simple to make with AoI, Blender, Sketchup or FreeCad. If you know how.
The one in the image, is made from identical roof module triangles), fit together and grouped. While that is a flexible and generic approach to enable many kinds of roofs with few models, it is a bit cumbersome. So, I think there are also some pyramid models posted in SourceForge (roofs).
For a pyramid roof, I would probably do like UbuntyBirdy, but for my own use I would probably also add a ceiling, sides and texturemap the roof (vt) so a texture (rooftiles) you add later will look the same on all sides, e.g. an .obj file looking something like this. Copy the text and save as pyramidroof.obj and import to SH3D (.mtl not needed for std colours: Java3DCubeColorsWithTransparency).
# pyramid roof with ceiling and texture co-ords g ceiling usemtl archwhite v 20 0 980 v 500 500 500 v 980 0 980 v 20 0 20 v 980 0 20 f 1 2 3 f 1 4 2 f 5 3 2 f 5 2 4 g side usemtl flwhite v 1000 40 0 v 1000 40 1000 v 0 40 0 v 0 40 1000 f 3 5 6 f 3 6 7 f 4 8 6 f 4 6 5 f 3 7 9 f 3 9 1 f 9 8 4 f 9 4 1 g roof usemtl redbrick v 500 540 500 vt -11 0 0 vt 0 0 0 vt -6 8 0 vt 6 8 0 vt 11 0 0 vt -6 0 0 vt -11 -8 0 vt 0 -8 0 vt 11 -8 0 vt 6 0 0 f 8/1 9/2 10/3 f 10/4 9/2 7/5 f 10/6 6/7 8/8 f 7/8 6/9 10/10
Re: Roofs
Maybe see if you could help youseeus on the roof plug-in he started to program.
