Total posts in this thread: 6
Previous Thread This topic has been viewed 1595 times and has 5 replies Next Thread
esse2003
Italy
Wall capy and paste
Hi all. Is possible to make a copy and paste of walls already built in another project? I need them with a certain angle, that’s the problem. Is that possible? I don’t want to import as an obj because then i cannot edit anymore. Thanks again!
[Jul 14, 2018, 6:39:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Wall capy and paste
You can select the walls you want to copy, choose Edit > Copy menu item, open the other project, click in its plan and choose Edit > Paste menu item.
[Jul 14, 2018, 7:33:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
esse2003
Italy
Yes, that’s correct but then i cannot give to the walls an angle? Right?
[Jul 14, 2018, 10:10:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe you could try AdvancedEditing plugin?
[Jul 15, 2018, 11:54:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
esse2003
Italy
I tried but you cannot do nothing with walls. There is not a function ti rotate walls unfortunately. Thanks anyway..
[Jul 15, 2018, 1:50:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I just tried and you can rotate walls with the plugin. Please try again.
[Jul 16, 2018, 9:30:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
