Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 1073802 times and has 196 replies Next Thread
Larz2
Re: Sweet Home 3D 6.0
Prices was what I was missing in former versions - Great work, thanks!
Though I agree with Hansmex, that it would be great if prices could be exported to CSV without currency, so numbers could be calculated in a spreadsheet.
Thanks, Best regards,
Larz2
[Jul 31, 2018, 12:54:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
After some additional tests, I noticed that prices followed by user's currency and percentages are correctly interpreted as numbers by Excel and OpenOffice when the CSV file is imported.
So I don't think there's a need to change the current format, moreover in case the currency is needed during a CSV import.
I'm more concerned by the encoding of the CSV file. At the moment, the encoding in use is the default one on the system where the the furniture list is exported. I propose to switch to the more versatile UTF-8 encoding to avoid problems between systems and if ever you need to choose another encoding, I'll add a system property for this purpose.
[Aug 1, 2018, 10:01:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
+1
No problem at home !
wink
[Aug 2, 2018, 5:59:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
By the way, this new feature
... I plan to improve the Material modification dialog box by allowing multiple selection in the materials list.
is very very practical and save much time!
[Aug 2, 2018, 10:29:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
Confirmed! This will be a highlight in the new version! SH3D 6.0 is one small step for Emmanuel (of course I know it's a lot of work and effort), but a big leap for mankind!
Pascal
[Aug 3, 2018, 4:54:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
Great work!!!!!!
I have an idea.
Can allow the furniture library to support the merging of multiple objects to form a new 1 object without increasing the file size of the furniture library
For example, multiple identical chairs and a dining table are grouped together.A variety of placement and color matching,File space occupying only 1 chairs and 1 tables
[Aug 13, 2018, 8:59:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rontant
Singapore
I ran this beta version before on my Win 10 machine. Now it won't run anymore. Here is the log content:
Java Web Start 13.0.2.0
Using JRE version 10.0.2+13 Java HotSpot(TM) 64-Bit Server VM
JRE expiration date: 16/11/18, 12:00 AM
User home directory = C:\Users\Xxxxx
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
0-5: set trace level to <n>
Warning: Java Web Start and Java Plug-in are deprecated and will be considered for removal in a future Java release. Please contact the developer of this content "PUYBARET EMMANUEL" and request an update for this program.
Insecure property: (com.eteks.sweethome3d.deploymentInformation, Java Web Start) specified in unsigned jnlp file will not be set.
Insecure property: (com.eteks.sweethome3d.applicationId, SweetHome3D#JavaWebStart) specified in unsigned jnlp file will not be set.
[Aug 13, 2018, 12:48:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I’m not sure it can run with Java 10. Could you uninstall Java 10 and try with Java 8?
[Aug 13, 2018, 1:43:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rontant
Singapore
Yes, I uninstalled Java 10 and tried Java 8. It works but the photo rendering option is now broken. I'll stick to 5.7 for now.
[Aug 14, 2018, 1:03:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Today, the Beta 5 brings the following features:
- A new indicator displayed in the middle of the selected wall to easily change its arc extent without the need to guess the right angle.
This should make it easier to create walls with smooth transitions, for example to create garden areas or round swimming pools.
- The ability to enter texts on multiple lines with options to align them.
When text alignment is set to Left, the rotation center will be at bottom left of the selected text, and when text alignment is set to Right, the rotation center will be at its bottom right.
- New Plan > Flip horizontally and Plan > Flip vertically menu items to flip the selected items around a vertical or horizontal axis. I hope you'll agree with the logic programmed to compute the symmetry of texts and furniture/room labels.
As announced previously, I also forced the encoding of exported CSV files to UTF-8 on all systems.
Finally, I tried to optimize how 3D walls are updated when doors and windows are changed, and slowdowns should be less present in case of a complex home with many walls and doors and windows.
[Sep 2, 2018, 5:50:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
