Индекс  | Актуални Теми  | List Attachments  | Търсене
 Добре Дошъл Guest  |  Регистриране  |  Вход
Псевдоним  Парола
Статус на Темата: Active
Общо съобщения по темата: 197
Съобщения: 197   Страници: 20   [ Предишна Страница | 11 12 13 14 15 16 17 18 19 20 ]
Създай нова Тема
Автор
Предходна Тема Тази тема е преглеждана 1167359 пъти и има 196 отговора Следваща Тема
Аватар на Участника
Присъединен: 8.04.2022 г.
Статус: Offline
Отговори на това съобщение  Отговори с Цитат
Re: Sweet Home 3D 6.0
(Posting in this thread because it's where the deformations were introduced.)
The mannequin has a great set of deformations for posing but... the deformations are not numbered like with hinges and rails. This means you can't have multiple mannequins in the same OBJ export because it breaks the deformations. Besides of course that you can't pose the mannequins individually.
I don't know if it's a lot of work but it would be nice if ALL possible deformations were numbered by default. It's not a great issue but it would support consistency in the handling of deformations.
Is there a list of all available deformations? I searched but can't find a complete list. For example the ball deformation is nowhere listed but is used in the MultiAxis example.
[15.06.2023 г., 17:22:24 ч.] Покажи версия за печат на съобщението    Прегледай Профила на Участника    Изпрати Лично Съобщение [Препратка] Моля преминете през Вход  Отиди нагоре
Аватар на Участника
Присъединен: 7.11.2005 г.
Статус: Offline
The list of deformations is at the beginning of ModelManager class.
And explanations are given in this thread about version 6.0, here and here (for ball-arm joints). Then Sweet Home 3D version 7.0 brought new prefixes to specify the moves of shapes relative to other moving shapes.
Actually, prefixes used for mannequin deformation are ball-arm joints, and since version 7.0, they could be replace by sub transformations. Then, you could use how many numbered ball-arm joints as you wish for more than one mannequin in a OBJ file. Nice exercice which requires some patience... If you succeed, please share your result smile
[17.06.2023 г., 17:40:43 ч.] Покажи версия за печат на съобщението    Прегледай Профила на Участника    Изпрати Лично Съобщение [Препратка] Моля преминете през Вход  Отиди нагоре
Аватар на Участника
Статус: Offline
Thank you. Some heavy experimentation to look forward to smile
[17.06.2023 г., 17:48:59 ч.] Покажи версия за печат на съобщението    Прегледай Профила на Участника    Изпрати Лично Съобщение [Препратка] Моля преминете през Вход  Отиди нагоре
Аватар на Участника
Статус: Offline
Just curious: why is it "arm_on_ball" and not "on_ball" like "on_hinge" and "on_rail"?
[17.06.2023 г., 17:50:43 ч.] Покажи версия за печат на съобщението    Прегледай Профила на Участника    Изпрати Лично Съобщение [Препратка] Моля преминете през Вход  Отиди нагоре
Аватар на Участника
Статус: Offline
I just used the same naming convention as opening_on_hinge_, window_pane_on_hinge_ and opening_on_rail_...
Good luck!
[17.06.2023 г., 18:54:22 ч.] Покажи версия за печат на съобщението    Прегледай Профила на Участника    Изпрати Лично Съобщение [Препратка] Моля преминете през Вход  Отиди нагоре
Покажи версия за печат на темата  Създай нова Тема
© Copyright 2024 Space Mushrooms - Всички права запазени
