Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 7 8 9 10 11 12 13 14 15 16 | Next Page ]
Previous Thread This topic has been viewed 727646 times and has 196 replies Next Thread
YGYL
Re: Sweet Home 3D 6.0
I think of an important thing
In the software setup interface or software installation interface, add a memory size setting option.
just like SweetHome3D.l4j.ini
The default use of 0.9G in software 32 is very small, and the 64 bit 4G is too small.Slightly more complicated rendering requires 10G's memory usage.
[Sep 24, 2018, 10:30:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great!
I love this version.
Just one question: Is max mem 14.2 Gb?
[Sep 24, 2018, 10:56:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe in a future version...
In 32 bit, a higher value won't work. In 64 bit, the default max is half of the available RAM.
Is max mem 14.2 Gb?
When run in 64 bit, the working limit must be the RAM size available on your computer when Sweet Home 3D runs.
[Sep 24, 2018, 11:37:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
To all <?> Ubuntu users who have problems running the beta version.
Thanks to the help of UbuntuBirdy I now can try the beta version 6. Here are the program lines you need:
[Desktop Entry]
Version=1.0
Name=Sweet Home 3D BETA 611
GenericName=Interior 2D design application with 3D preview
Generic Name[de]=Innenraumplaner
Comment=Interior design Java application for quickly choosing and placing furniture on a house 2D plan drawn by the end-user with a 3D preview
Comment[de]=Innenraumplaner zum Auswählen und Platzieren von Möbeln auf einem 2D-Hausplan mit 3D-Vorschau
Path=/home/hans/SweetHome3D-beta611
Exec=sh -c "/home/hans/SweetHome3D-beta611/SweetHome3D-Java3D-1_5_2" %U
Icon=/home/hans/SweetHome3D-beta611/SweetHome3DIcon.png
StartupNotify=true
StartupWMClass=com-eteks-sweethome3d-SweetHome3D
Terminal=false
Type=Application
Categories=2DGraphics;3DGraphics;
Keywords=interior;design;2D;3D;home;house;furniture;java;
MimeType=application/sweethome3d;
Name[de_CH]=SweetHome3D BETA 611
Note the following:
- you can change the Name and GenericName to whatever you like
- you can leave out the Comment lines
- you can change [de] and [de-CH] to your own language
- in the path names change "hans" to your own user name
- make sure that the path name /SweetHome3D-beta611/ points correctly to your file (name and location)
- open a Text Editor and copy the above text
- save and name the file xxx.desktop where xxx is the name you want
- then copy the script to /home/hans/.local/share/applications/
- this is a hidden file, so you need to do CTRL-H to show the file
- under the start button, type SW and SH3D should show up
Thank you very much Birdy!!!
[Edit 1 times, last edit by hansmex at Sep 24, 2018, 10:40:43 PM]
[Sep 24, 2018, 11:50:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
alaX
Poland
So many new great features - oh, Emmanuel, please don't stop tongue
Due to "3d error" I had to install 6.0 beta 11 with "j3d.version=1.5.2" (Win 7, 32bit) and now it works nice.
[Sep 24, 2018, 4:55:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
Glad I could help you, Hans.
There are two great programming highlights since time immemorial: once Linux and of course SweetHome3D!
The result is a law of the universe: who's able to use SweetHome3D on a Linux-System, will be happy!
And of course I will try to make as many people happy as possible by showing them how to use SweetHome3D on Linux.
A humble servant of the universe
Pascal
Pascal
[Sep 24, 2018, 10:07:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Not important, but there MIGHT be a bug here:
[Sep 25, 2018, 1:43:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
digitaltrails
New Zealand
Works fine in OpenSUSE (Linux) Leap 15 if the SweetHome3D-6.0.beta11/SweetHome3D script is modified to useOffScreen3DView:
-Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true
Tried the Outward opening window and the Mannequin - awesome!
If I don't set useOffScreen3DView it dies during startup with:
com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x33d6ba0, context 0x3db1f88, drawable X11OnscreenGLXDrawable[Realized true,
Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@964c9ab,
Handle 0x56000a1,
Surface JAWTWindow[0x24dca16d][JVM version: 1.8.0_181 (1.8.0 update 181)
JAWT version: 0x10004...
[Sep 26, 2018, 10:30:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
confused Re: Sweet Home 3D 6.0
Yesterday, I saw an anomaly with 6.0 beta12.
Case 1
When I used a new furniture 6.0 like a window, all was OK.
The update of a height don't change anything.
Case 2
The same used window but I used 'modify openings'.
The option 'keep proportions' is checked and became unavailable !
Why ?
[Sep 27, 2018, 9:35:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your feedback smile
Ceciliabr, I already noticed the difference between the requested amount of max memory and the actual value reported in the About dialog box.
It's not a bug, but Java probably rather uses the difference for internal management (see this technical article if you want to learn why).
digitaltrails, fortunately you had the idea to test com.eteks.sweethome3d.j3d.useOffScreen3DView.
It's probably another solution that I should better document, just because I keep in mind to test it from time to time to check if it still works.
bdfd, the behavior you noticed is normal. As said in a previous post:
As soon as an object is deformed, its size can be changed only proportionally, otherwise this could lead to strange shapes.
If ever you need a wider or deeper or higher object, first reset its shape, change the dimensions you want, and deform again its shape.
[Sep 27, 2018, 2:39:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
