Re: Light properties
The property is lightSourceColor#..., fully black matching no light, and white #FFFFFF matching a white light at full power. See DefaultFurnitureCatalog.properties for examples.
You will, as indicated by Puybaret, need to adjust RGB down in sync. The power is, however, saved in Home.xml, as that reflects the adjustment made by the user in the design.
You can find all the properties in DefaultFurnitureCatalog.PropertyKey.html. ... The power is, however, saved in Home.xml, as that reflects the adjustment made by the user in the design. ok
Great ! Do you know how to update this data in a sh3f file ?
Use a zip utility to extract the PluginFurnitureCatalog.properties file from a SH3F file and rezip it at the end, and a text editor to edit the PluginFurnitureCatalog.properties file.
Sorry if I was unclear. There is no power setting in .sh3f/PluginFurnitureCatalog.properties (only in .sh3d/Home.xml). In .sh3f/PluginFurnitureCatalog.properties you can use the html (six digit hex) colour notation:
a very bright white light would be:
lightSourceColor#xxx=#FFFFFF
a 'normal sh3d white' lightsource is (if I remember):
lightSourceColor#xxx=#BBBBBB
a much less bright 'white' light would be:
lightSourceColor#xxx=#222222
TY okh.
Damned, a parameter only manually update.
Perhaps a adding to do in whislist section for next 5.8… .
@bdfd
I want to change the default value (50%) to 5% (for example).
This is possible in a derived version of SH3D by modifying line 53 of the HomeLight.java file.
TY enkonyito.
But I don't like this because it's "all or nothing"...
I explain : I want to update ONE object in a sh3f not all objects of same type in SH3D.
[Edit 1 times,
last edit by Puybaret at Jun 6, 2018, 1:31:07 PM]
